Natalies 67- Bump
BlueOvalDave
Re: Natalies 67- Bump
Post by BlueOvalDave »
Yes it is but I need to get my pinion angle down. It's pointing up towards the bed, I need to get it to point towards the trans.
And while I'm here, anyone have an idea why my headlights are flickering bright to dim, and I lost my taillights but I do have brake and turn signals. I can hear the headlight switch faintly clicking while the lights are going goofy. I replaced the switch. No change. I thought maybe in the process of chopping the bed and frame I screwed up a ground so I ran a dedicated ground from the battery negative to the frame and another from the bed to the frame in the rear. Still no good. It was working fine before the chop though.
I'm open to all ideas.
cole71
Post by cole71 »
Right, so with the thick end toward the front it points the angle down? That's what I was confused on which way should the shim be placed to either drop or raise the angle.
BlueOvalDave
yes it points it down
cole71
Post by cole71 »
Ok thanks for clearing that up! I thought it was the other way for some reason?
BlueOvalDave
no problem I think I was scratching my head too when I first got them.
Now if you could fix my lighting problem...................
J/K
This yellow/black connection is getting quite warm, almost too hot. I dont have any additional lights that would necessitate the need for a relay, seeing as how it functioned fine for all these years without one.
BlueOvalDave
I figgered it out. Heat made me think resistance, which further cemented my belief that I screwed something up when I did the chop. That connector is for the running and tail lights so upon backtracking the wiring again it was pinched in between the gas tank and frame, which must have happened when I dropped it to weld the rear frame brace in.
Whew, like I need any more problems. All good, thanks for looking!
Craigerf100
Post by Craigerf100 »
Hey none of your photos are working :(
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
My Build: :fr: http://www.fordification.com/forum/view ... &sk=t&sd=a
cole71
Post by cole71 »
Glad it was a simple fix!
BlueOvalDave
Wooops, I inadvertently deleted them. Here they are
Imagems/u63/BlueOvalDave/nanas%20bump/055_zps7f5e5c60.jpg[/IMG][/URL]
Craigerf100
What Do they call that paint, satin black? Love the look. The same look I'm going for. What motor is that again? Great project repost More pics :thup:
BlueOvalDave
It's val-spar low gloss black, also known as John Deere black, blitz black etc. 30 dollars for a gallon, it's oil based so it does have it's drawbacks. It will fade over time, it shows hand and fingerprints. The plusses are the price, you can touch up any scratches with a sharpie :lol: and you can shoot it in your garage with a run of the mill breathing regulator. If you choose to repaint with a real automotive paint the car will have to be stripped, (as there will be a reaction between paints) which is what we plan to do this winter. This is just a stopgap measure as there is a ton of body work that needs to be done, and will get done proper now that I'm not as rushed.
But thanks for the nice words fellas, always appreciated :thup:
rumblin46
Post by rumblin46 »
Dave...Any chance you can re-upload the roof repair? In process of doing some right now:
https://flic.kr/p/nHkcDe
https://flic.kr/p/nH3gSV
69 F100 - Coyote - Gen II Flavor
BlueOvalDave
soon as I get home this afternoon. Computer I'm on now wont let me see your flicker acct.
BlueOvalDave
First off, That's a nice sounding GT. And your from The Land Of Corruption too, being a Mustang mod motor guy are you familiar with Mike Post? Very good ford tuner. Anyway back to the roof, it appears you have a complete donor roof which will probably make your job that much easier, but I'm not so sure that my repairs will do you any good but here goes. Very amateurish work on my part but I'm more interested in the mechanicals than the aesthetics. I really need to redo the mud work, maybe this winter
The hardest part will be chasing the rust around to find good metal to weld to. In some areas I backed it up with strips of 18 ga so I wouldnt blow thru. Good luck
Imagebums/u63/BlueOvalDave/nanas%20bump/nanasbump029.jpg[/IMG][/URL]
rumblin46
Post by rumblin46 »
Thanks for the pics, looks pretty good all things considered. Thanks for the comments on the car (it's for sale :D ) and I do know Mike, he tuned the car!
