PaPa's 69 F100 Explorer Coyote 10R80 swap
- Venomous duck
Re: PaPa's 69 F100 Explorer
More markings found
- Venomous duck
This is on the bottom side.
- Venomous duck
On to sand blasting.
- Venomous duck
Powdercoated in semi gloss black.
Last edited by Venomous duck on Thu Feb 11, 2021 10:09 pm, edited 1 time in total.
- Venomous duck
I used a large file then a sander to clean up the machined surfaces. Doing this caused the loss of the machine marks but I had to get rid of the pits.
- Venomous duck
Finished housing.
- hfdco4
Dam dude, you are really making progress. I also pulled my springs apart and cleaned them up. I know they were coated with some kind of black coating. I painted mine with a Grafite Paint called EZ-Slide. I didn't find any insulators between the leafs, but they also could have been apart before.
FE390PC
- Venomous duck
I am really confused about the silver paint I found. I hope someone can comment on that. Someone painted on the black, turned out the third member had been painted as well, more to come on that. I really considered the EZ slide but wound up going with the spring liners. I am going to try to post more tomorrow, more to show on the rear end.
- Venomous duck
Next up is the third member, chunk, pumpkin or the thing that goes inside the housing. The third member had been painted with a spray can Black. This was a surprise as it meant someone had been inside it before. I also noticed black spray paint on the leaf springs that I did not understand. I really searched my memory for an answer. As I stated early on this truck has been in the family since new. Because I am really the only one to work on it since the early 80's I knew this must have been done early in it's life. Finally it came to me. When I was a kid probably around 10 yrs old (this must have been around 74) I remember visiting my grandparents. My Grandfather whom is the original owner was telling my parents about a kid taking the truck for a joy ride, (all keys were always in the ignition on the farm). I don't know who it was but I think it was a second cousin or something. Anyway he got it stuck in the pasture and somehow destroyed the rear end. Not an easy thing to do to a 9 inch. It was never spoken of again. The good thing for me is that the poor paint job preserved the marking underneath. The paint came off with little effort.
- Venomous duck
Disassembly started
- Venomous duck
Turns out it has the correct Ford 3.25 ratio gear set, but Timken bearings.
- Venomous duck
More disassembly
- Venomous duck
Empty Case
- Venomous duck
New parts
- Venomous duck
This is a 2.75 gear set I thought I would see if I could clean up.
