MLJJONES67 PROJECT CUMMINS put away for winter
- 460 crew
Lookin good your starting quite the collection.LOL I have no Idea what those box things are. Hope someone chimes in. Maybe their spare nuts and bolts holders
How hard of a swap will it be to put the 67 on the 79?? I know the bed will bolt on in different places. Will the cab just bolt on in the same locations? How about the front bumper? I am guessing the high boy springs will bolt right in also?
I like the idea of power steering.
I think I will use just the core support.
I don't like the look of the newer innerfenders, and the mounting the hood would be a pain in the rear.
Any suggestions??
Lots of runnin questions
Any suggestions??
- Art
"box" things hanging on frame
They are charcoal canisters... emissions equipment. Nut and bolt holders would be more valuable in my opinion...460 crew wrote:I have no Idea what those box things are. Hope someone chimes in. Maybe their spare nuts and bolts holders
owner of several 67-72 as well as 73-79 Ford trucks
Wanted: Parts for my 1930 Dodge coupe project - the DD model was built in 1930 and 1931
Like vintage drag racing? http://www.meltdowndrags.com
I will be using the 79 frame to put my 67 body on. I am converting to a 6bt with a zf s5 42 and the mated np205. I will most likely put an aluminum flat bed on it. I have decided to stick with the bump inners, I don't like the newer inners. They don't look sturdy enough. Even though they might be I however will be using the core support.
Thanks for the info Art.
- averagef250
2wd body, 79 frame, cummins engine, late model tranny.... What's 67? Maybe you could reuse the radiator cap or the steering wheel? Sounds like an easy way to get everything you need Mike. If you go with a flatbed it shouldn't cause any complications. Mounting a bed on the later frames isn't very simple. Holes are different, that's not hard to figure out, but the later trucks have a longer wheelbase too.
re: mljjones67 project update
It will definitely be a Heinz 67!!! It will look like a 67 drive like like a 79. Sound like a diesel. Hmmm the best of all worlds.
I am not into concorse restorations. Restomod is the way I roll I am all for functionality and originality. I hate following the in crowd. Never have never will. Plus not many people will know the difference in the frames. Now the diesel they will figure out. Just what I like.
- Manny
Re: "box" things hanging on frame
Yeah art right on teh money but i've never seen two on one truck?? Where was that one built at to include two of them???Art wrote:They are charcoal canisters... emissions equipment. Nut and bolt holders would be more valuable in my opinion...460 crew wrote:I have no Idea what those box things are. Hope someone chimes in. Maybe their spare nuts and bolts holders
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
Dustin,
wondering if this turbo will work for my setup????
http://www.ksl.com/?nid=218&ad=3223638&cat=&lpid=
- rjewkes
I've never seen them on the frame in that locality, usualy just a few inches from the rad support just under the alternator area on the frame.
fuelly.com
fuelly.com
- averagef250
That turbo won't work. Common rails have a different turbo mount. That's an HE351, not a good turbo. You can upgrade your turbo with a 12-16 CM turbine housing from an H1C or an HX35 or you can just run an HX35. The H1C is the older design used on 95 and older dodges. The 94/95 H1C's are called WH1C's and were the same turbo you have with a 12CM wastegated turbine housing. In 95/96 the HX35 came out, it's the same size compressor and exhaust and dimensionally identicle, but it's more efficient.
- averagef250
