BobbyFord Short Bed
hfdco4
Re: BobbyFord Short Bed
Post by hfdco4 »
Any updates Bobby?
:fr: FE390PC
BobbyFord
Post by BobbyFord »
I wish. Life is getting in the way of my trucks right now. :(
Hoping to get this truck painted soon.
hfdco4
Post by hfdco4 »
I hear you Bobby. Didn't get out to do anything this weekend and next weekend doesn't look good either. I have to travel for work on the 12th so I will be away on Valentines day which makes for limited truck time. :(
:fr: FE390PC
Manny
Post by Manny »
BobbyFord wrote:I wish. Life is getting in the way of my trucks right now. :(
Funny how that goes. Having that same problem right now hope to catch up tomorrow and hope you get back to it soon!! :thup:
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
BobbyFord
Post by BobbyFord »
Thanks buddy!
crazyhorse
Post by crazyhorse »
Mr Bobby, I :pray: hope that is a happy, healthy, busy life getting in the way and you "find" time to get back working on the trucks.
Wishing you the best.
I enjoy your posts/photo/information.
God bless you sir.
Bullitt74
Post by Bullitt74 »
I hope you can find some time for your project when the timing's right. Until then, know that your knowledge and expertise is much appreciated by us 'newbies'. :wink:
Steve F.
Red Deer, Alberta, Canada
8)
hfdco4
Post by hfdco4 »
Any updates yet Bobby?
:fr: FE390PC
BobbyFord
Post by BobbyFord »
Electric fan with shroud and fan controller.
hfdco4
Post by hfdco4 »
Looks real good! Great to see you back at it!
:fr: FE390PC
BobbyFord
Post by BobbyFord »
Thanks bud. I’m working long hours and have two trucks apart 🫤
The short bed only needs paint at this time but my focus is my Unibody.
JWW
Post by JWW »
Looking good. :pop:
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
My project: http://www.fordification.com/forum/view ... &sk=t&sd=a
BobbyFord
Post by BobbyFord »
JWW wrote: Tue Jun 27, 2023 3:36 pm Looking good. :pop:
Thank you.
BobbyFord
Post by BobbyFord »
I haven’t worked in two months. Almost had back surgery. I still might need surgery.
Decided to try to get that hood scoop going.
This shaker hood scoop is a replica of a 1969 Mustang shaker hood scoop. Many pieces.
The difference between the Mustang and my F100 is, the carb on my truck is closer to the cowl than it is on a 1969 Mustang. Also, the F100 has 1-1/2”offset to the right. I need to offset the scoop left and about 3” forward to make sure that the scoop is in an aesthetically pleasing location in the hood. I chopped the crap out of the intermediate plate and discarded the flapper and vac diaphragm.
I made a plate out of mild steel and moved the rear attachment points from the flapper plate forward onto my plate.
I bought the 16” concourse replica air cleaner base for $400 and immediately chopped it up
BobbyFord
Post by BobbyFord »
It took me a while to piece in some metal, this air cleaner base is thinner gauge than the original so it is difficult to MIG weld without blowing holes in it. I made a little progress today.
There are two more handmade pieces that will go into the bottom of this base. The air filter will be an 11” K&N Xtreme (with open filter top.)
I figure once these pieces are in place, I will need to increase the overall height of the air cleaner base about 1” to 1-1/2”, meaning I will cut around the circumference and add a band of 22 gauge sheet metal to increase the height.
