Well, I spent my Memorial Day in the shop getting started on the bed repair. I thought I'd better add the "again" in the topic title since this I believe this is the third time I've started a topic with that title, each time with a different bed, only to find out that it was total garbage...which meant it got thrown out and the search for another bed began. Well, like the old saying goes, 'third times a charm'. The SWB bed is actually in very good shape...at least compared to the other two I attempted to resurrect. The side panels on this one are virtually rust-free, aside from a little surface pitting in a few spots, and the bottom side is in great shape....heck, even though the inside floor has pitting, the bottom side of the floorpans actually still have the factory primer on them. Even though the topside of the bed will require work smoothing dents and filling some holes, the bottom side will basically just need to be cleaned up and painted.
If you recall, the only two areas of rust that will require patches were the rear floorpan lip and a 6" x 8" spot around the left/front bed mount hole. I decided to get started on the rust repair today, beginning with the rear lip area. The left/rear flat section of the bed floor had a few pinholes right where it met the wheelwheel, and at first I was just going to leave it and just cover it up with the spray-in bedliner, but I decided to just go ahead and get it all cut out, as long as I was here doing the work. Here's a before shot of the rear area:
I spent the first hour just cleaning the shop, making room for me to work. Then I got the bed off the truck and into the shop, where I set it up on four 55-gallon steel drums and then got to work cutting the rear floorpan section out. Here's a shot after that section was removed:
I had the bed floor from the '72 SWB I parted out (back on Page 52) which was in good shape, so it became my patch panel donor. After a LOT of cutting, trimming, grinding, etc., here's a shot of the final patch panel just lightly clamped into place...and this patch panel is all one piece:
It took me right at 12 hours to get this done...it was extremely time-consuming work to keep trial-fitting the patch panel and make adjustments with the grinder to make it fit. However, this section is 99.9% ready to weld in. I'm not going to attempt to butt-weld the corrogated section, I cut this with about a 1/8" overlap and will weld it in like that. There will be a tiny lip where the two meet, but by the time it's welded in, ground down and then finally covered with bedliner, it'll be virtually invisible.
I worked on this until after 10 PM last night, and by the time I got home and cleaned up, and got something to eat, it was after midnight. Even though today (Monday) is still the Memorial Day weekend, I have to go to work for a few hours. Later this evening I'll try to get another project update page done, detailing the day's activities.
The bed repair begins....again [LG PICS]
- FORDification
- Site & Forum Admin
re: The bed repair begins....again [LG PICS]
looking good keit... I think your bed has been probably your biggest headache in the build so far if i'm right but it looks to me like things are coming together and fast heck before you know it you'll be done...Terry
The dumbest question in the world is the one you don't ask.
- MAK
What do you use to make the initial cuts to remove the rusted sections? Sawzall with a metal blade or air powered cut-off wheel or nibbler? If I can ever get my practice welds acceptable I need to start cutting out some rusted sections. I feel better about the floor I have to work with after seeing all the work you are having to do. Looks good.
- FORDification
A majority my cutting is with a cut-off wheel in the 4½" angle grinder, with a few small chunks here and there done with the air chisel, if it's inaccessible to the grinder.
Yes, since it's been a while since I used my MIG, and the last time I did the results were barely acceptable, I'll be doing some practice welding myself before actually attempting to weld these patch panels.
mig welders are nice but you have to be good with them to make it look right....you just need to finishing cutting the bed out put you some tubbs in it and narrow your rearend...oppps got carried away......
- ToughOldFord
Nice work, takes patience that I just don't have anymore.
There was a '61-66 F-100 I used to see around town quite often, he added 2 feet to the long bed so he had a 10ft bed on the truck. Did such a good job it looked factory. Was odd though, seeing that much bed beyond the rear axle.
- CJ,s 67 F100
Its coming together good it looks like. This is making me want to start looking for my "next" project Great job Keith
