Anyone make a wiring harness specificly for our trucks?
oldschoolrods
Post by oldschoolrods »
I was doing a little searching today, making a list of stuff and kind of pricing seeing how much I would ultimatley have in my truck to finish it the way i wanted...which will take a while lol But anyway I was wondering if anyone made a wiring harness specificly for the 67-72s. I checked painless and they make 67-72 chevy of course :cuss: and EZ wiring has universal kits. I could probably do a universal kit because my electrical skills are pretty good i think anyway. But I think a specifc kit would be easier? Thanks if anyone can help.
FORDification
Site & Forum Admin
Site & Forum Admin
re: Anyone make a wiring harness specificly for our trucks?
Post by FORDification »
I've never seen or heard of one that is '67-'72 specific. I don't think there'd be a large enough market for those to cover manufacuring costs...though I could be wrong.
tcb1969
Post by tcb1969 »
I would think that a universal kit would work pretty well for our trucks - especially 67-68 models. The wiring is pretty simple compared to a car - especially a newer model.
If you were careful, you could run all the wires and bundle them together and then just wrap any exposed wires for protection and to give it the 'factory' look.
Would you trust a 30 yr old tire? why trust 30 yr old wires?
A complete re-wiring is definitely high on my list. And I'd like it to be nice and compact, like the newer vehicles. Plus think of the benefits of modern technology - you could run a kickin stereo and all the lights you wanted. Plus - you're gonna get a one-wire 100 amp alt. to go with it!! :wink:
and then there's a/c - and then the power windows and door locks, with keyless entry for the shaved door handles!! :twisted:
sorry - got a little carried away.
John
Kaylle
Post by Kaylle »
I have thought about making a wiring harness before. I have made them for some equipment I work on. Start with a piece of 3/4" plywood about 2Ft by 4ft.. Use an old wireing harness for a pattern. lay the old harness out on the board. Use finishing nails to make a tight path on both sides of the Old wiring harness(space nails about 1/4" apart and let then stick up an 1"). With the nails make a tight path for each set of wires that come off of the main set of wires.(light switch, wipers, radio, blower motor,etc.) Put a larger nail at the end of each path to wrap the new wires around to pull them tight. After you have the "Bed of Nail" done. Then you just route the new individual wires in one at a time. Have large nail at the end of each wire run to pull each wire tight. After all the wires are laid out on the board. Tie the wires together with wire ties, lacing twine, electrical tape, or what ever works best. Then cut the wire ends at the large nails and then you have a New Wiring Harness. If it works in your truck, you will have the Bed of Nails set up so you could go into buisness making wiring harnesses for 67-72 trucks. After the first set it gets easier.
Kaylle Jonas
67 F100 SWB 429 C6
66 F100 SWB 390 Car 4spd Toploader 3.5 Traction Loc
65 F250 LWB 352 Granny 4spd
Monroe NC
FoMoCo
Post by FoMoCo »
Has anybody looked at Bare Bones wiring. Better value that painless for sure.
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
fisheye
Post by fisheye »
T think I just saw an ad in a magazine that Painless has just made one that fits our trucks. I will check later and verify this information.
A senior citizen still having fun but just getting slower.
fisheye
Post by fisheye »
I found it on the Painless Wiring website and here is the picture.
bluef250
Post by bluef250 »
Has anyone priced the harness?
Yes.
We talked about it on this thread:
http://fordification.com/forum/viewtopic.php?t=2160
fisheye
Post by fisheye »
Try Ron Francis Wire Works at www.wire-works.com He makes a lot of wire harnesses for hot rodders and can custom make one. I don't know the range of his prices but you can request a quote.
Norm
460 crew
Post by 460 crew »
Has anybody checked this company out? http://www.enoscustom.com/blackbox.html
