Thank you
240/300 I6 Acceleration/Transmission Linkage
- JWW
I have a 240 that I'm working to get back together. However, I'm missing parts to get the "kick down" fully connected. Below is a diagram of the accelerator and transmission linkage (courtesy of FORDification). I am missing the parts that I have highlighted. I'm not too concerned with some of the bushings or washers. However, I do need the part numbers 7A394, 380340-S. I'm open to buying the full assembly as well if you don't have individual parts.
![Image](https://bn02pap001files.storage.live.com/y4m4vkXvgRErZcVZayboVlsqDDgurBCVL0vg8HqRl0ydPMLCxB31L8F-jiiwxhnh9Fok_fKMGzb04ko4W4fbJFmiUFckxxJ4uin_81v6nMSkOjsCzTZ_OZUoMdyk00u3PW9d4eu3KglFzhn2Rw8O3X6PolxPRcxZW851riUG8vhOqv9zyTzC60h9ihfrTcGr_ot?width=4032&height=3024&cropmode=none)
Thank you
Thank you
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
2004 F150 Crew Cab
Re: 240/300 I6 Acceleration/Transmission Linkage
i have a complete setup off a 67 in very good shape, but its for a 3 speed manual on column. you may need different parts if you have an automatic.
just a thought.
just a thought.
- JWW
Thanks. Is your setup for sale?67 short box wrote: ↑Sun Sep 10, 2023 9:06 am i have a complete setup off a 67 in very good shape, but its for a 3 speed manual on column. you may need different parts if you have an automatic.
just a thought.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
yes. make offer.
- JWW
Can you post pictures of your set up? I want to be sure I don’t already have the parts. Thanks again.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
after looking at mine, i dont have those parts you have highlighted.
- JWW
Thanks for checking though. I appreciate it.67 short box wrote: ↑Mon Sep 11, 2023 8:04 am after looking at mine, i dont have those parts you have highlighted.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
