Heater Core - keep or get new?
JWW
Post by JWW »
I have finally disassembled my heater box. I do not plan to drill out the rivets; I will try to clean the best I can. I would like some advise on the heater core itself. Is there a way to check for leaks at home? Finding a radiator shop these days is hard and a new core is not too expensive. I'm curious what you all have done. Thanks
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
Fraser
Re: Heater Core - keep or get new?
Post by Fraser »
In the past, I have just run a garden hose in both directions until it runs clear. If you can't pressure test it how about vacuum? I have no experience with the repops, so no opinion there.
Was your heater full of mice? I have found they will return no matter how much you clean, however painting the inside of the plenum seems to seal their scent so they are not drawn back.
F. Noble, Saskatchewan.
jzjames
Post by jzjames »
Heater core; mine leaked and I just got a new one. Radiator shop said he didnt recore those.
JWW
Post by JWW »
Fraser wrote: Wed Jun 07, 2023 10:59 pm In the past, I have just run a garden hose in both directions until it runs clear. If you can't pressure test it how about vacuum? I have no experience with the repops, so no opinion there.
Thanks, luckily no mice. I'll do some cleaning with a hose and see how it ends up.
jzjames wrote: Thu Jun 08, 2023 10:16 am Heater core; mine leaked and I just got a new one. Radiator shop said he didnt recore those.
Makes sense. Hard to find anyone any longer that does this type of work.
JWW
2004 F150 Crew Cab
cep62
Post by cep62 »
You could use a bicycle inner tube and pressurize it and dunk it in a tub of water to check for leaks.
But I hate doings things twice , if I have it apart I'd probably put a new one in .
JWW
Post by JWW »
cep62 wrote: Sat Jun 10, 2023 2:01 pm But I hate doings things twice , if I have it apart I'd probably put a new one in .
Thanks, think I’ll get a new one.
JWW
2004 F150 Crew Cab
basketcase0302
Post by basketcase0302 »
Def worth the $58 dollars investment! The rivets really aren't that big of a deal and by going into the box you'll also find it needed some new foam weatherstripping to properly seal air that was by-passing the heater core.
DC is out of them but I bet LMC or my fav NPD has them:
https://www.dennis-carpenter.com/trucks ... wstd-heate
Mach428
Post by Mach428 »
You are working on a vehicle over 50 years old. If you can’t find a radiator shop to recore your original (absolute best option in my opinion because you know it fits) then invest the coin for a new one. Your time is worth more than doing this job more than once.
JWW
Post by JWW »
basketcase0302 wrote: Fri Jun 16, 2023 5:15 pm Def worth the $58 dollars investment! The rivets really aren't that big of a deal and by going into the box you'll also find it needed some new foam weatherstripping to properly seal air that was by-passing the heater core.
Thanks. I found most everything on LMC. I’ll drill the rivets out since I have it out of the truck.
JWW
2004 F150 Crew Cab
JWW
Post by JWW »
Mach428 wrote: Sun Jun 18, 2023 2:32 pm You are working on a vehicle over 50 years old. If you can’t find a radiator shop to recore your original (absolute best option in my opinion because you know it fits) then invest the coin for a new one. Your time is worth more than doing this job more than once.
Agree, thanks. It feels good to refurbish what you can too.
JWW
2004 F150 Crew Cab
