Coil springs
timmytim
Coil springs
Post by timmytim »
What is the proper way to remove front coil springs at a pull a part...I normally use a spring compressor tool or a floor jack to slowly let it down. Pull a part don't let me bring in jacks.
:fr:
buy'em dirty sale'em clean
get more money for the same
machine.....
:loco:
My 1967 bump: http://www.fordification.com/forum/view ... 09#p668209
My 1970 Bump: http://www.fordification.com/forum/view ... 16&t=50726
cep62
Re: Coil springs
Post by cep62 »
Loop a chain through it so it doesn't get away from you. ? ?
timmytim
Re: Coil springs
Post by timmytim »
That's a good idea bud
:fr:
machine.....
:loco:
basketcase0302
Re: Coil springs
Post by basketcase0302 »
Like CEP said above, I can remember using ratchet straps years ago for safety, (can't remember if I ever tried compressing them using ratchet straps or not)? :hmm:
6Delta
Re: Coil springs
Post by 6Delta »
Any chance you might find a scissor jack in one of the other vehicles? I dropped the front springs out of a Firebird once using a jack from a Eagle Talon and a bicycle cable with its padlock. The chain idea is better but I used what I had in the trunk. Do they want to rent you a jack? My days of dropping a transmission onto my chest are long past. I know I have seen a cherry picker pulling a motor at one of the local you-pull-it places but that was a while ago.
No Brain - No Pain
71 F250 Sport Custom Camper Special
71 Ranchero Squire
70 Ranchero GT (Red w/351C 4V
70 Ranchero GT (Black w/302+)
03 Kawasaki Vulcan 750
74 Kawasaki H2 750 (Widowmaker)
75 Firebird 400
71 XKE FHC 4.2
04 XJ8 4.2
timmytim
Re: Coil springs
Post by timmytim »
I've been lucky and found couple trans removed and laying on ground under car. I hope they didn't have run to take a bathroom break....lol
:fr:
machine.....
:loco:
Generalee0527
Re: Coil springs
Post by Generalee0527 »
The pick a part I frequent leaves vehicles up on home-made stands of steel wheels welded together so everything is extended. I just knocked bottom shock bolts out and then unbolt the top. Then deal with the long bolt thru the i-beam. Be sure to keep the perch on top of i-beam. They are hard to locate separately. :D
68 Ranger. 302 Clevor w/ 3 on tree, soon to have front disc brakes.
