PaPa's 69 F100 Explorer Coyote 10R80 swap
Venomous duck
Re: PaPa's 69 F100 Explorer
Post by Venomous duck »
Electrolysis process using carbon rods. This prevents the rust coming off the anodes which makes such a mess.
Venomous duck
The results are amazing.
Venomous duck
Ring gear and worm drive differential installed
Venomous duck
Final Checks
hfdco4
Post by hfdco4 »
Like the carbon rods for electrolysis. Where did you get them?
:fr: FE390PC
JWW
Post by JWW »
Great post! Thank you for sharing your knowledge and reference pictures.
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
Venomous duck
Paul, the carbon rods came from everyone's favorite online hardware supply, McMaster Carr. They are not expensive and much better then using steel.
Your solution stays much cleaner. The rods do wear out but last quite a long time. I will never use steel anodes again.
JWW, thanks, I appreciate you taking time to comment. Glad your getting something out of it.
hfdco4
Post by hfdco4 »
No, thank you for another good source of tested information!
:fr: FE390PC
Fordkid68
Post by Fordkid68 »
Awesome thread! Great project! Can't wait to see more!
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
Venomous duck
Thanks guys. I haven't actually been able to work on it since November. I do have more progress "in the can" that I will post as soon as I process the pics. I have been spending all my free time remodeling a house to sell. it's just about finished. Then I can get back to work.
Venomous duck
This will be the restoration of the two rear axles. Starting with the before pictures.
Venomous duck
Here you can see the condition of the axles. Pretty typical.
Venomous duck
Next I put my bearing splitter on it so I could press it out with my 20 ton HF press.
Venomous duck
I put all 20 tons of pressure on it but it did not budge. Total fail, don't even try it. I decided to cut the bearing and spacer off. This turned out to be super easy and simple.
Venomous duck
Next I used a chisel to knock the race off.
