71 F100 SB 4x4 Edel Pro-flo 4 EFI install
My427stang
Post by My427stang »
Thought I would show some updates of my old F100
I built a 461 FE, ported iron, Comp custom hyd flat tappet cam, 9.75:1, .041 quench, and did a quick cam break-in and dyno pull on a Duaspark 2 and 850 Holley, with the ported Edelbrock EFI intake on it and injectors hanging. We didn't bother tuning, it was a little fat, and just wanted to see what it liked for timing and break in the cam. It made 490 HP @ 5000, and 554 ft lbs of torque. Two different runs here, but you can see, nice flat curve even with a ported Victor intake. it's a baby compared to most of the FE strokers I do for others, but what a joy in a 4x4 pickup
I put it in the truck, drove it for a while with a 3310 750 and the Duraspark to get an idea of power and performance, and then hooked up the EFI
I made a goofy video at initial start up, wires everywhere (all cleaned up now) however, it ran really well. The fuel pump needs to go, but I had a slight air leak on the suction side and it's significantly quieter, but not quiet enough.
At this point, I am tweaking the program, letting it learn a bit, but it is incredibly well behaved around town already and getting better. 14-15 inches of vacuum is great for power brakes, and it's super mellow mellow until you drop the hammer. I need to modify my pedal to allow full throttle, so I can't really tell if it's making more power, but I believe it is more responsive and likely will be equal or better to the carb, as my big FEs tend to like airflow
Enjoy!
https://youtu.be/bmVY8NeWJgU
390FE1972
Re: 71 F100 SB 4x4 Edel Pro-flo 4 EFI install
Post by 390FE1972 »
Nice looking setup! Thanks for sharing. 8) :thup:
basketcase0302
Post by basketcase0302 »
Woohoo... :woohoo:
I'd love to hook a prop onto the end of that many ft pounds of Ford to show the chebbyu boyz what real power is! :D
Congrats on a nice build! What fuel cell or original tank? :thup:
Nice. That fuel pump is obnoxious... :D
My427stang
DuckRyder wrote:Nice. That fuel pump is obnoxious... :D
Indeed, it is a little better, I had a slight leak on the input side, found when I had some fuems after sitting overnight, but still unacceptable
It's a very good pump, but Deaschwerks said "You picked the right pump, but the loudest one we sell" LOL I have two FEs to dyno and deliver this weekend, then I will come up with a plan. I have a nice big quiet Mallory, but it hangs below the frame and seems to not look right for a 4x4, even if it never goes off road.
basketcase0302 wrote:Woohoo... :woohoo:
I used the original tank and added a pickup, and use the original feed as a return, all NiCopp lines, here is the inprocess pic. If the paint wasn't recent, I may have considered an under bed tank, but this is a nice tank and works well. I have considered an aftermarket fuel cell behind the seat, and still may, but wanted to make sure the EFI was happy before I made even more changes.
basketcase0302
Awesome job!
Congrats on the HP! :thup:
Big specht
Post by Big specht »
You could of used a pump from a 7.3 power stroke they are the same style as in mounting and plumbing BUT a lot quieter. Lol but it looks good and to hear it helped the drivability of it. The price for those kits aren’t that bad when you figure buying a good new carb and all the stuff to jet it right.
Olbluetardis
Post by Olbluetardis »
"I built a 461 FE, ported iron, Comp custom hyd flat tappet cam, 9.75:1, .041 quench, and did a quick cam break-in and dyno pull on a Duaspark 2 and 850 Holley, with the ported Edelbrock EFI intake on it and injectors hanging. We didn't bother tuning, it was a little fat, and just wanted to see what it liked for timing and break in the cam. It made 490 HP @ 5000, and 554 ft lbs of torque. Two different runs here, but you can see, nice flat curve even with a ported Victor intake. it's a baby compared to most of the FE strokers I do for others, but what a joy in a 4x4 pickup"
I'm a newbie and dont really know what any of this stuff means. But I can see the squiggly lines going up so I'll say nicely done!
