Parting out 71 f100
Parting out 71 f100
71 f100 shortbed, no motor or trans, truck has original power steering and original power disc brakes.
Re: Parting out 71 f100
What are you asking for the front disc brakes?
Looking for an automatic column as well
Thanks
Thanks
Make me a fair offer.
- urchinhead
Do you have intact factory (Carlite) back glass? Solid, not a sliding window.
If this truck is a 4-speed, I am interested in the column.
Thanks!
Thanks!
1970 F100 Custom 2WD, SWB, 360 FE, np435
1964 Galaxie 500 Convertible, 390, Cruise-o-Matic
http://i171.photobucket.com/albums/u309 ... fa6562.jpg
I do not have the back glass. And no I don’t believe the truck was a 4spd.
- urchinhead
I just stripped a clean 1970 auto column for the wiring/turn signal and small hardware. Not power steering though, but a clean housing with longer manual steering shaft if anyone wants these parts for the cost of shipping.Blue_Streak wrote:What are you asking for the front disc brakes?
Thanks
- hdman90
Any chance you could send and/or post pictures of what you have?
What are you looking for?
Pic
So the column is an automatic?71bumpside wrote:Make me a fair offer.
TBH I don't know what a fair value is for each of those!
You have basically just the longer manual shaft? No shift lever , no steering wheel , no wiring , no turn signal , and no small hardware whatever that is. Is that correct?urchinhead wrote:I just stripped a clean 1970 auto column for the wiring/turn signal and small hardware. Not power steering though, but a clean housing with longer manual steering shaft if anyone wants these parts for the cost of shipping.Blue_Streak wrote:What are you asking for the front disc brakes?
Thanks
The missing parts …….. do you know if they are readily and easily available from aftermarket for a rebuild?
- urchinhead
It has the shift lever. Are you interested, or should I put this in the dumpster?
I’m restoring a crew highboy just found bed not repairable. Can you pm me or call 402681 four zero three six. Thanks
Will you sell the bed ?
I was trying to get more information on sale of parts but guy hasn’t been online since 2/26
