390 Aluminum intake?
wyngnut55
Re: 390 Aluminum intake?
Post by wyngnut55 »
Update: Turns out my 390 is a 360. Not the original engine according to the placard on door. To add to that, it is a service engine block. The sides of the block casting are ribbed. I didn't know that was the sign of a service engine. Machine shop said its a 360 crank and rods. He showed me 390 rods vs 360 rods. 390s are beefier. I guess some folks prefer service engines? Don't really see any advantage to it or why that would be true? Shop has a 390 crank and rods he is giving me. Crank has to be machined. Have H304P pistons .040 over on back order. Gonna be a pricey rebuild. Was thinking of just ordering a rebuilt 390 long block I've seen on eBay for $1700 + $300 shipping and about $500 core. Who knows the quality and the problem there is the engine is in pieces and its not a 390 core. Auto parts stores are about $2400/$2500 and say they need the same engine core or no refund. ATK does't have any 390's.
Russ
71 F100 Ranger XLT, 390, C6, 2wd.
I would build the one you have, particularly if you’re getting the 390 crank and rods gratis...
Parts store rebuilds and eBay rebuilds are high risk...
GaryKip
Post by GaryKip »
Have you checked out "S and J engines" Ford-360-ci-5.9-liter-remanufactured-long-block-engine
FOR-360LB
Engine
Fuel Type
Gas Fuel System
Carbureted Cylinders
8 Engine Type
OHV V8 Engine Size - C.I/Liters
360/5.9 Transmission
Auto or manual VIN Type
Y
Installation Instructions
Pre-lube and Break-In procedure, engine oil and gasket kit shipped with engine. Professional installation recommended Engine Description
1968-1976 Ford truck applications; IMPORTANT: Correct installation procedures, post-installation diagnostic documentation, break-in procedure and warranty contract registration required for warranty considerations. Professional installation recommended. Head Cast
Block Cast
Crank Cast
1961 1976 Ford F-250 390/6.4 Auto or manual 500.00 1839.00
[Arrow] Add to Cart
S&J-Ford-6.4L-390-ci-remanufactured-long-block-engine
FOR-390LB-1
Engine
Fuel Type
Gas Fuel System
8 Engine Type
390/6.4 Transmission
H,Y,M
Pre-lube and Break-In procedure, engine oil and gasket kit shipped with engine. Professional installation recommended. Engine Description
1961-1976 RWD, 16 Valve, with smog, 8 bolt exhaust,4 bolt motor mounts Head Cast
Block Cast
C8AE-C, C7AE, C2AE Crank Cast
2U, 3U, C1AE
1961 1976 Ford F-250 High-Torque Cam 390/6.4 Auto or Manual 500.00 1899.00
[Arrow] Add to Cart
Ford-390-c.i.-6.4-Liter-long-block-crate-engine-remanufactured
FOR-390LB-RV
Engine
Fuel Type
Gas Fuel System
8 Engine Type
Auto or Manual VIN Type
N/A
1961-1976 With RV cam, 4 bolt motor mount Head Cast
Block Cast
Crank Cast
1961 1976 Ford F-250 390/6.4 Auto or manual 500.00 1899.00
[Arrow] Add to Cart
FOR-390LB-3RV
Engine
Fuel Type
Gas Fuel System
8 Engine Type
N/A
1961-1976 Ford w/ RV cam, 2 bolt motor mount Head Cast
Block Cast
Crank Cast
1961 1976 Ford F-250 390/6.4 Auto or manual w/o smog 500.00 1839.00
[Arrow] Add to Cart
Ford-390-c.i.-6.4-Liter-long-block-crate-engine-remanufactured-Cobra-Falcon-Galaxie-Torino-Cougar-Thunderbird
FOR-390LB
Engine
Fuel Type
Gas Fuel System
8 Engine Type
Z
Break-in oil, engine pre-lube and break-in procedures and gasket kit shipped with engine. Professional Installation recommended Engine Description
1961-1976 Without smog, 4 bolt motor mount; IMPORTANT: Correct installation procedures, post-installation diagnostic documentation, break-in procedure and warranty contract registration required for warranty considerations. Professional installation recommended. Head Cast
C8AE-A C8AE-B D2TE-AA Block Cast
C8AE-C C8AE-A D3TE Crank Cast
2U, 3U
Lowest Price Guaranteed (800)942-7800
The right engine the first time, guaranteed!
S&J Engines Include:
Engine described is a remanufactured long block engine. Long block engine includes:
7-Year/100,000 mile warranty
Exceeds OEM quality and specs
Installed precision milled cylinder head(s)
Valve train:new valves, seals, and seating
Milled Cylinder Head/s
New Main Bearings
New Oil Pump
New Pistons
New Rod Bearings
New Timing Belt
Not included: air cleaner, ignition, valve covers, timing cover, intake manifold and oil pan
GaryKip
Post by GaryKip »
Make sure that you pick the correct engine, some have smog stuff. The last 390 does not have smog.
wyngnut55
Post by wyngnut55 »
I made the decision to rebuild what I have about 10 days ago, can't go back now. I can also do a little performance rebuild as I originally hoped. The poblem with the long block thing was shipping cost and excepting a 360 service engine core in pieces for a 390 long block. Even if I put it back together (without gaskets) it might not be excepted. After paying those extra costs the prices get pretty close.
Thanks for the info though.
Russ
wyngnut55
Post by wyngnut55 »
Update...Thank you Duckryder for all the valuable info. Engine is in and truck is back on the road today. Runs great! Held off on the intake and 4 barrel carb for another day project. Haven't pulled any long grades yet or whomped on it but I think I may be hearing a slight ping when accelerating on freeway. Timing is 6 deg BTC.
Russ
redstone65
Post by redstone65 »
That's a great looking engine. So, in the end, no aluminum? All iron?
Dave
‘65 F-100 (240) Former military truck
‘70 F-100 (360) restoring with my son
