Bed Mat
RangerRat
Bed Mat
Post by RangerRat »
Does anyone know if a rubber bed mat is available specifically for the 67-72 f100? Or if one from a newer model will fit with minor trimming?
Idaho Chris
Re: Bed Mat
Post by Idaho Chris »
RangerRat wrote:Does anyone know if a rubber bed mat is available specifically for the 67-72 f100? Or if one from a newer model will fit with minor trimming?
Here us a photo of the bed mat I recently installed in my '69. I bought the mat from JC Whitney. It is nice heavy rubber, but have to cut it to fit. Not a big deal though.
-Chris
1969 F250 4x4 4spd 300 I6
1973 Mustang Mach 1 351C
3 Speed
Re: Bed Mat
Post by 3 Speed »
Image[/quote]
Chris, is that one piece, or did you cut some other material to fill in front and back of the wheel buckets?
67 F101 Custom Cab longbed, 352 V8, 3 speed manual
Idaho Chris
Re: Bed Mat
It is one piece.
-Chris
3 Speed
Re: Bed Mat
Post by 3 Speed »
Chris, if you have the part number or description, please tell us. I looked online at J.C. Whitney and could not find what you have - which is a great solution.
Thanks!
Idaho Chris
Re: Bed Mat
3 Speed wrote:Chris, if you have the part number or description, please tell us. I looked online at J.C. Whitney and could not find what you have - which is a great solution.
Thanks!
Here is a link to the bed mat I bought:
https://www.jcwhitney.com/results/?Ntt= ... global&N=0
If for some reason the link doesn't work for you, my invoice shows it listed as part# W16506325
-Chris
RangerRat
Re: Bed Mat
Post by RangerRat »
What did you use to trim it to fit?
Idaho Chris
Re: Bed Mat
RangerRat wrote:What did you use to trim it to fit?
I used a utility knife with fresh blades. I went through four blades to do the job.
I laid the mat out on the concrete driveway next to the truck. I'm a little anal about getting it right so I probably spent an hour on the project. I wanted the mat symmetrical in the truck bed so I first identified a center line on the mat. I then snapped a chalk line down both edges of the mat and cut the excess. From there I used a large square and took my time cutting out for the wheel wells. We are fortunate that the wheel wells are perfectly square so getting a good fit was easier. I made all my cuts against a 4' long straight edge.
The mat is a little wider and longer than needed so it can be cut to fit perfectly. Good luck!
-Chris
GPatrick
Re: Bed Mat
Post by GPatrick »
I looked around and found that a number of places sell the Westin 50-6325 that JC carries. Best price I found today with free shipping is at Jegs - $129. Thanks for the heads-up on the mat. https://www.jegs.com/i/Westin/978/50-63 ... 0UQAvD_BwE
Gary
Littleton, CO
Idaho Chris
Re: Bed Mat
JCW frequently has 15-20% off sales if you register with them. I think I was all in around $130 when I bought my mat.
-Chris
crazyhorse
Re: Bed Mat
Post by crazyhorse »
Mr Ranger, I saw this on Craigslist.
I don't know anything about it.
https://greenville.craigslist.org/grd/d ... 47094.html
michael69
Re: Bed Mat
Post by michael69 »
So this bed mat that link and part# was posted for is made from two different styles of molded rubber? It looks like regular bed mat in middle part between fender wells and like a diamond plate design in front and behind the fender wells on sides ?? Thanks for any help
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
Idaho Chris
Re: Bed Mat
michael69 wrote:So this bed mat that link and part# was posted for is made from two different styles of molded rubber? It looks like regular bed mat in middle part between fender wells and like a diamond plate design in front and behind the fender wells on sides ?? Thanks for any help
Yes. The mat is one piece but it is molded with two styles; regular in the middle and diamond plate on the sides. That is why it is so important to get the center-line of the mat identified so you are trimming from both sides evenly.
-Chris
michael69
Re: Bed Mat
Post by michael69 »
Thanks, thought that was how I was reading it and wanted to make sure.
Michael69
Zorm
Re: Bed Mat
Post by Zorm »
humm, wonder about cleaning up the bed, seal the floor also seal the underside and "glue" down this mat?? thoughts
