Color code for white bumpers/grille
Does anyone know the color name or paint code number for the white that was used on 1968 F100 painted bumpers and grille? Thank you for your response.
Re: Color code for white bumpers/grille
Should be.
Wimbledon White M
Wimbledon White M
- 3 Speed
Check other posts. I think the guys on here say this paint was Corinthian White, while Wimbledon White was used for body panels.
67 F101 Custom Cab longbed, 352 V8, 3 speed manual
I did a search on other forums as 3 speed suggested and the answers were all over the place such as
No one quoted actual Ford references so I am not posting the above quote as fact. Thank you for your suggestions,"Standard Cab hubcaps were not painted body color, they were painted Colonial White, which is a 'bright' white. This color was used 1948/69 for hubcaps, grilles, bumpers.
Exterior aka body colors: Corinthian White (code M) used 1961/63, Pure White (code C) 1964/68, Wimbledon White (code M) was introduced in 1964."
Dig through the color chips in the homepage as well as the brochures...
One of them has a note on it that says that all bumpers and grills were _____ even if the body was another white. I know I’ve seen the note but can’t find it now.
I want to know what color of white was used on the factory wheels?
1967 F-100 4x4 custom cab.
- 3 Speed
My wheels and bumpers are the same color - a slightly yellow/beige off-white, which seems to correspond with Corinthian White. See the image in my signature.
My truck is a 67 Custom Cab, which came with painted bumpers, regular hubcabs, painted wheels, but with the bright aluminum grille and chrome around the windshield.
