Power steering cooler
Ron_Hall
Post by Ron_Hall »
Hey guys.. anyone have a better idea for the power steering cooler than the oem one? ...just looks like it doesn't belong. 8)
Thanks
Ron
1971 F100 SWB 390 FE - bored.030 over
Edelbrock Performer - Holley 600 CFI
Stock heads with some porting - Sanderson FF427 Headers
C6 with stock converter - 3.25 rear end gears
One owner...
Ranchero50
Re: Power steering cooler
Post by Ranchero50 »
There's one that runs along the drivers side frame rail that isn't too hateful. Looks like the back of an old refrigerator. Just a hard line that runs back and forth.
Busboy
Post by Busboy »
Hayden makes small coolers that mount in the airflow pretty cheaply. I prefer the original design however.
1967 F-100 4x4 custom cab.
Ron_Hall
Post by Ron_Hall »
Ranchero50 wrote:There's one that runs along the drivers side frame rail that isn't too hateful. Looks like the back of an old refrigerator. Just a hard line that runs back and forth.
Busboy wrote:Hayden makes small coolers that mount in the airflow pretty cheaply. I prefer the original design however.
Thanks Ranchero50 and Busboy, This is the one I was thinking about getting and put it in the frame rail.
Thanks
Ron
One owner...
Ranchero50
I don't think it's really needed. Have you felt the lines after driving it hard in the twisties to see of the PS system is generating a lot of heat? I don't have one on my truck with a front wheel load of 6400 lbs and the system stays relatively cool.
Ron_Hall
Post by Ron_Hall »
Ranchero50 wrote:I don't think it's really needed. Have you felt the lines after driving it hard in the twisties to see of the PS system is generating a lot of heat? I don't have one on my truck with a front wheel load of 6400 lbs and the system stays relatively cool.
Ranchero, It's never been driven since I put the ps unit on but that's what I'll do, run it without and see if I do need it. Can always add it later.
Thanks
One owner...
Busboy
Post by Busboy »
I'm thinking it may have been a patch repair for the weak Bendix style p.s. box that was discontinued mid 69.
Ron_Hall
Post by Ron_Hall »
Busboy wrote:I'm thinking it may have been a patch repair for the weak Bendix style p.s. box that was discontinued mid 69.
Good thought Busboy... Thanks
One owner...
Ranchero50
Didn't Ford use them extensively in the '70's? I thought that's where the one in the pic was sourced from. Little ******** would cut the snot out of you in the dark.
Nitekruizer
Post by Nitekruizer »
I installed the type made of tubing that mounts along the frame rail. It came from a Dentside. They are not a direct bolt in. Unless you bend them somehow or add to their length, like I did, they hit the x-member and won't fit. Not a big deal, but I thought it worth mentioning.
Ron_Hall
Post by Ron_Hall »
Ranchero50 wrote:Didn't Ford use them extensively in the '70's? I thought that's where the one in the pic was sourced from. Little ******** would cut the snot out of you in the dark.
Nitekruizer wrote:I installed the type made of tubing that mounts along the frame rail. It came from a Dentside. They are not a direct bolt in. Unless you bend them somehow or add to their length, like I did, they hit the x-member and won't fit. Not a big deal, but I thought it worth mentioning.
Thanks guys for the input, I decided to just take it off for now and see if I really need it. Looks a LOT cleaner without it!
Ron
One owner...
Jacksdad
Post by Jacksdad »
Ranchero50 wrote:Little ******** would cut the snot out of you in the dark.
:lol: :lol: :lol: :lol: :lol: :lol: :lol:
