Hole in firewall...?
- Bullitt74
Steve F.
Red Deer, Alberta, Canada
Re: Hole in firewall...?
For your speedometer cable.
- Bullitt74
Hmm, my speedo cable comes through another hole just to the right of that one:
Looks like it has a fairly robust grommet as well, so not sure if I can move it without damaging the grommet.
Thoughts?
Thoughts?
Steve F.
My speedometer cable comes through your open one. Has a foam gasket much like the one on the heater cable...
- Bullitt74
I wonder if my body man routed the speedo cable through the wrong hole? Seems like more of a straight shot to the cluster to route it through the hole that is open. If that is the case, I wonder what is meant to route through the hole that my speedo cable currently goes through?
Steve F.
I’m having trouble locating the one your speedo cable goes through.... picture from firewall side?
- Bullitt74
Sorry - the second pic was from inside the cab,
Steve F.
- Ranchero50
I'd lay money that's where the heater temp cable comes through.Bullitt74 wrote:I wonder if my body man routed the speedo cable through the wrong hole? Seems like more of a straight shot to the cluster to route it through the hole that is open. If that is the case, I wonder what is meant to route through the hole that my speedo cable currently goes through?
Heater cable goes through over the passenger side valve cover. 2 Wiring harnesses over the driver side valve cover speedo cable over booster in the vacant hole in the first picture. Another wiring harness over the near the hood hinge.
- Bullitt74
Thanks Robert! Going to rejig these around a bit. Sounds like I didn’t need to drill a hole in my firewall earlier for some add ons...
Steve F.
See if this helps:
Pardon the filth, gotta clean it up...
- Bullitt74
this is perfect - thanks Robert!!
Steve F.
