New MSD drop in ready to run distributor Part 2
72bumbee
Re: New MSD drop in ready to run distributor Part 2
Post by 72bumbee »
Well thanks again for all the help!!!
I will time it again and get the mush out of it!
Any ideas on the air filter?
“To succeed in life, you need two things: ignorance and confidence.”
Mark Twain
1972 F-250 Camper Special. 360 A/T P/B AND a DANA 60 Rearend!
Former owner of dads 1967 F-100. It has gone home to the big road in the sky...
Oh yeah...
I’d probably just stick a “hi-po” air cleaner on it... You can get them from any of the mustang suppliers. It should come with a fitting to attach the holes to.
How much does it lack clearing?
72bumbee
Post by 72bumbee »
The front edge of the filter can is sitting snug on top of the plug wires, actually off setting the thing enough to cause the carburetor to rev a bit when I screw it down
Mark Twain
You might be able to get a spacer at summit racing, assuming you have hood clearance...
https://www.summitracing.com/search/par ... ly-spacers
72bumbee
Post by 72bumbee »
Saw the price tag on those mustang filters and almost pitched a clot.... I’ll look at spacers... I think I should have enough clearance for just lifting it off the new dizzy
Mark Twain
72bumbee
Post by 72bumbee »
Would anyone know offhand what my carb throat diameter is?
Mark Twain
72bumbee
Post by 72bumbee »
Autolite 2100
Mark Twain
Been a while since I had an 2V around, but you should be able to measure the hole in your stock air cleaner. I am pretty sure it is the same as a Holley 4V.
colnago
Post by colnago »
If so, you might be able to find a spacer at the local AutoZone.
Joseph
72bumbee
Post by 72bumbee »
I keep forgetting the local “Auto-China” has that stuff!
I went in there and asked about the remote starter doohickey.... they all kinda stared at me like I had a horn poking out of my forehead.... finally, the head goober looked it up and found a dusty dirty package in back...
I digress...
I’ll run in tomorrow and ask about the spacer... is there a specific verbage I should use to make it easier for them to find?
Mark Twain
Go here and take a screen shot with your phone and take it with you.
https://www.autozone.com/intake-system/ ... dapter-kit
colnago
Post by colnago »
Either that, or ask for a spacer for an Edelbrock air cleaner. I think my local AutoZone is "iffy" on Edelbrock stuff, but the local O'Reilly carries it.
Joseph
72bumbee
Post by 72bumbee »
okay. I thank you ALL for the great advice!!
I get 5 1/2 at my base of air cleaner.... all the diagonals on the spacers seem to max out at 5 1/4
for eight bucks ill give it a shot....
hope my breather tube is able to reach...
Mark Twain
