68 crew cab going on a 2001/02 f250 frame
68crewcab
Post by 68crewcab »
newproject. i found the 99-04 leaf spring chassis to have a narrower track width than the 05 up chassis.thats why i picked the early chassis.also found that if you use the 05 up wheels on it, you narrow the track width about 4 more inches,making it about the same as the 68 [need to use 18 inch wheels to clear the tie rods].here is a picture of one of the cab test fits.in the picture the cab is about a foot higher than it will be
hfdco4
Re: 68 crew cab going on a 2001/02 f250 frame
Post by hfdco4 »
Can't wait to see more pictures! :thup: :D
:fr: FE390PC
popeyes71
Post by popeyes71 »
Sweet, can't wait to see this project come together! :thup:
-Popeye-
1971 F-250 4x4 Highboy
68crewcab
Post by 68crewcab »
here are some more pictures.one of the floors being worked on and one of the dash i am making[not finished yet]
68crewcab
Post by 68crewcab »
a swap meet find. picture of the factory storage box that goes behind the seat when you remove the fuel tank . doing a test fit in the crew cab
Manny
Post by Manny »
Man some neat stuff going on here can't wait to see more of it! :thup:
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
1969 Crewcab
Post by 1969 Crewcab »
I have a 69 crew and am interested in your build. You make any progress?
