72 F-250 Ranger XLT in Portland OR area
Bought a 72 Ford Ranger XLT 2wd F-250 a couple months ago. Paid under 1900 for her. She had very loose steering - I replaced tie rod ends and drag link. Drivers door did not open from the inside - bent mechanism. Spark plugs were very loose in rebuilt 360 (about 30K on the engine). High and low power steering pressure lines were both leaking - replaced. C6 transmission coolant lines were laying against exhaust - zip tied away from exhaust for now. One coolant line was completely backed out of where it goes into the transmission and leaking like crazy. I pulled and redid all the woodgrain on tailgate and side trim (bought replacement woodgrain vinly off Ebay). Truck has HEI distributor but had burned a hole in the top of the cap - replaced cap and rotor. Rag joint has been replaced but steering wheel is at 5 o'clock when going straight down the road. I think the previous owner did not have the steering wheel straight when he replaced it - he may not have been able to tell how far off it was because of all the play in the steering. I have a bad rear cab mount I have to tackle on the passenger side. I already bought the sheet metal piece from Dennis Carpenter - I'll definitely need some advice before I do it. Front seal leaks in the transmission but it shifts fine and does not slip when full. I picked up most all of the factory ac pieces to add later. 360 has a 2bbl manifold with a holly carb that I want to upgrade to 4bbl with edelbrock or carter afb carb. Truck is single exhaust and I want to upgrade it to dual. I picked up a factory radio for it and am going to mount a 7" flip out touch screen stereo under the dash.
Re: 72 F-250 Ranger XLT in Portland OR area
- Manny
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- popeyes71
-Popeye-
1971 F-250 4x4 Highboy
- Bullitt74
Steve F.
Red Deer, Alberta, Canada
I'm jealous.....you've got my favorite color combo......
1997 Honda CBR 900RR
Thanks all!
Really appreciate the comments. She's a work in progress but I will probably start a restoration posting. Big challenges ahead - passenger cab mount, transmission repair, factory ac install and... Also still need to do the brakes, install the dvd 7" flip out stereo under the dash, install new window channels.
