Hello from WA
Hello from WA
Hi Folks
Angus here from WA. Recently got into my first f100 -
It is a 72 swb with a recon 390, restomod-ish. Definitely a work in progress and looking to get help in completing a couple jobs - trivial to some no doubt and mostly electrical in nature.
Angus
Angus
'72 f100 swb
'17 audi allroad
'15 toyota highlander
wife & 2 kids
'17 audi allroad
wife & 2 kids
Re: Hello from WA
Here she is
'72 f100 swb
'17 audi allroad
wife & 2 kids
'17 audi allroad
wife & 2 kids
- 1970FordTK
Re: Hello from WA
Nice one, welcome from North Carolina.
- Mancar1
Re: Hello from WA
Good looking truck
Good looking truck
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Re: Hello from WA
- Manny
Re: Hello from WA
Very nice welcome from Ga!!
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- popeyes71
Re: Hello from WA
-Popeye-
1971 F-250 4x4 Highboy
Re: Hello from WA
Thankyou everyone for the hearty welcome. Almost 1 week into my 72 Ford F100 ownership and learning new things every day.
There seems to be a wealth of great info in the different categories and a well-organized forum at that.
The things I am looking to tackle on the truck (and not limited to) in the short term:
Front right parking brake light not working (suspect it's a bulb which is on order).
No horn, don't know if it doesn't exist or just not wired up (still need to investigate)
Turning signal - I hear the clicker but no indicator on the dashboard
Fuel gauge has no reading (tested it and I think it's the sender unit - on order)
Ignition has separate keys to that of the door(s), presume one can replace the barrels to be uniform. Also the housing for the ignition twists in its casing.
Ignition has an aftermarket starter button which has resulted in some sort of bastardization of the ignition - not sure what I am going to do here.
Looking at getting a tonneau cover
'72 f100 swb
'17 audi allroad
wife & 2 kids
'17 audi allroad
wife & 2 kids
Re: Hello from WA
Re: Hello from WA
HEYO! welcome from the south sound of WA! LOL
I need a cover for my truck as well. The rainy season is right around the corner.
-d
-d
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
- 67mann
Re: Hello from WA
Not sure if this the reason but, there is a ground wire on the rag joint(from nut to nut)which is and was commonly broke due to weargoat_72 wrote:Thankyou everyone for the hearty welcome. Almost 1 week into my 72 Ford F100 ownership and learning new things every day.
Re: Hello from WA
So this may be a valid issue, but I can't actually find the horn/siren in the engine bay anywhere. Perhaps I add the la cho cha rach air horn i always wanted.
'72 f100 swb
'17 audi allroad
wife & 2 kids
'17 audi allroad
wife & 2 kids
Re: Hello from WA
So roughly a month plus into ownership of my ford f100. I have really enjoyed the experience thus far of driving it and I also have relished having a bit of a work truck for my garden / domestic jobs.
That said, as I mentioned before a work in progress so I can provide some updates.
a. I purchased a cover from it for $99 and it works great. IM me if you want details as I don't want to do any public product promotion.
b. Status on the horn ... well to begin with there is no horn fitted, but I can see the cable for it. I think the horn relay switch is buggered, and I don't see another cable for the horn that is supposed to be on the driver side. quick question, are the horns in series on the same cable or independent. I could not make sense of the schematic.
c. new tires, repacked bearings, have made a huge difference to handling and steering.
d. replaced sending unit in the fuel tank and now get 1/4 tank reading on a full tank of gas. I am only getting 1.5 volts to the gauge / sending unit, so I have an instrument panel voltage regulator on order.
e. fixed parking light switch on brake pedal
f. replaced the dimmer switch on the floor, works great.
h. flasher wasn't coming on front right indicator lite, saw one of the elements on the bulb was broken.
overall, i have enjoyed the troubleshooting and tinkering. I get questions all the time and comments about the truck when I go out and folks, for the most part, supprised to see it full of garden waste. These cars were built to work
... and finally with or with or without a load I still only get 9mpg
'72 f100 swb
'17 audi allroad
wife & 2 kids
'17 audi allroad
wife & 2 kids
