I've completed an install of a new (to me) AC system on my truck, but I don't know how much refrigerant is supposed to go into the system. And since its a system I put together, there's no manual or anything to look at. Everything is new, and I'm using a Sanden style compressor.
So can anyone tell me how much refrigerant I should expect to use? Should I go by trial and error using vent temp?
Need help!!
How much refrigerant to charge AC?
- Gray035
1968 F-250 Camper Special
Re: How much refrigerant to charge AC?
Around 28 oz I think. At least that's what Google says. ![Doh :doh:](./images/smilies/icon_doh.gif)
- 1972hiboy
which a/c system are you using? new aftermarket or an old system?
Rich
Dont eat yellow snow.....
I have a '76 that I converted to R134a. I put around 1.8 lbs in. It works well. I would maybe try for 2 lbs if I were to do it again though.
- Gray035
The system has a new 508 syle Sanden compressor coupled with an old dealer add on evaporator unit. The condenser is a universal aftermarket one.
- 1972hiboy
I would expect somewhere in the 1.5lb to 2 range. Do you have manifold gauges? what freon are you planning on running?
Rich
- Gray035
It's a dealer add on unit, but with a new Sanden compressor and new everything else. I put in about 26 oz and it's pretty cool coming out of the evaporator, but I think that I might add a little more.
- Gray035
