1967 mercury m-100 352 auto
good evening all,
after almost 10 years since i bought this truck i finally have the extra $ to give it a start. she is a factory black with white cab (f-100) but badged as a mercury way back 50 years ago for sale only in canada.... custom cab with a 352 automatic. rare truck. survivor. body is in excellent shape with a fine rusty patena . look forward to gaining some knowlege on suspension upgrades and tranny/engine reconditioning.i didnt even know ford made a 352......i have a donor truck at the farm for parts....and bring the merc into the city for the work ... still not sure if i am affecting the trucks value with modern upgrades...but im looking forward to a winter with her in the garage. my 17 year old nefew asked if he could drive it for grad in the spring of 18' . ive got 9 months. again i am happy as hell to have a group of individuals to lean on for advice and guidance. thank you FORDification!!!
Re: 1967 mercury m-100 352 auto
Are you in Canada? I'm in Alberta and am also working on a '67 Mercury M100. It is a 352, 4 speed 4X4. This one is all red and with the Ranger package. No power steering but am looking at an electric upgrade for the steering. The 352 was the only optional V8 offered by Ford that year and they were painted gold color. And don't let anyone tell you different! Ford started painting their truck engines blue in 1968 when the 352 was dropped and the 360 was introduced and also a 390 optional engine was available. Ford ceased production of Mercury trucks in March of 1968 so yes they are getting rare. The Mercury brand started in January 1946 and our family has owned a few. I still have a M350 dually one ton custom cab, 292 Y block 4 speed and a 1949 M155 3 ton "wide axle" 239 flathead V8, 4 speed, 2 speed rear axle. Both of these trucks are for sale if anyone is interested. Good luck with your project, keep us informed and we will help you along.
oh,gold block 352? my block is blue. truck is unmolested. was a radio delete, has the knock out still in it...i guess there is the possibility som,eone in the 70's did a swap...but it would have had to been a good one..... i will post pics this weekend if someone can tell me how...... was there a possibility some blue block 352's made it in? yes to alberta.
Welcome from Michigan! I've never seen a mercury in person so I'll be watching. It's pretty neat having a few mercs in this forum. Good luck and god speed!
Kyle
Kyle
Looking forward to seeing your truck!
from Massachusetts.
thanks boys,
i will post some pics as soon as i can, it is a very original truck. im curious as to if it is a 352 now , as the fella said those blocks were painted gold.this one is blue. is there a block stamping that someone would be able to point me too? where to look?
I had an older motor in my 72. It had the 352 and the block was black. The only gold was on the valve covers. I ended up painting it all gray. You never know if someone just repainted it. I believe mine was stamped 352 on the front of the block by the water pump.
Kyle
Kyle
i have the 352 stamp, also i checked the autolite carb, it was for a 352. i try to add photos, but the system says they are too large what can i do? or didnt do?
I use image shack for my photo hosting site but there are many other hosting sites out there. Download your pictures into there then copy paste them over to here.
Kyle
Kyle
- Mancar1
Welcome aboard from Northern, Ca.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- colnago
All of the FE blocks have the 352 cast into them, whether they are really 352, 360, or 390. They all use the same block, just different bore and stroke.d7savage wrote:i have the 352 stamp, also i checked the autolite carb, it was for a 352. i try to add photos, but the system says they are too large what can i do? or didnt do?
For posting photos, I load them onto my PC, then use some photo-editing software to lower the resolution. If I really need the detail, then I'll crop it. I've posted videos to YouTube, then posted a link here.
Don't know about the Mercury line, but '67 was the last year that Ford used the 352 in a truck in the States. I also don't remember the year they switched, but older engines were a dark blue, and newer engines were a lighter blue. Mine should be dark, but VHT either had the cans mislabeled, or their color team is color blind, so mine is the lighter blue. I suppose that's okay, because I actually prefer the lighter blue color.
Oh, and welcome from SoCal!
Joseph
https://imageshack.com/a/nOKl/1
oh i think i made this happen. please let me know if you can see the pictures! as you can see block is blue, but im unsure of the lighter and darker blue.... and where my color fits... there is not one difference between this and a ford of a same vintage, besides the mercury tailgate and hood lettering and side badge. the curious thing is the weird tag on the firewall. all numbers match of course....but i think this truck was made somewhere in the usa then shipped to Canada, rebadged and sold here.not canadian made. if i read it right it was made in Chicago..... check the images and lemme know what you guys think.
- colnago
What I got from the VIN:
F10YCA28073 (the frame stamp looked like a 'G', and the VIN plate looked like a 'C'; since a 'G' is not valid, I figured it has to be a 'C').
And using the VIN decoder here:
http://www.fordification.com/tech/VIN67.htm
F10 = F100
Y= 352
C = Ontario, Canada
A28073 = October, 1966 build date
Also, your VIN plate says "Made in Canada". Looks like your truck is a legit Mercury, not a rebadged Ford.
Joseph
F10 = F100
Y= 352
C = Ontario, Canada
Joseph
