another hello from california
Hi guy's I'm also taking the time to introduce myself along with a pic of my project 70 F-250 but, I guess the file is to big. I'll post it when I figure out to make it smaller. Anyway look forward to communicating with fellow bump-side enthusiast.
- calipilot227
Re: another hello from california
Try opening it in a browser and save the thumbnail instead of the full size photo
My Ford: 1970 F250 Camper Special (360, C6, 2WD, drums all around)
My Daily: 1998 Volvo S70 T5
"In the beginning, God made the light.
Shortly thereafter, God made three big mistakes.
The first mistake was called "Man." The second mistake was called "Wo-man."
And the third mistake was the invention of the poodle."
- 67mann
from NY
from Massachusetts.
- MadJoe
I've had luck with posting the photo to Facebook then opening it in a tab and copying the link from the address bar then posting it as a link here. I use FB because imgr, photobucket, and Google photos are all blocked by my work VPN, but any of those 3 should also work to link larger photos, but I won't be able to see them until I check on my phone or get home.CobrajetF-250428 wrote:Hi guy's I'm also taking the time to introduce myself along with a pic of my project 70 F-250 but, I guess the file is to big. I'll post it when I figure out to make it smaller. Anyway look forward to communicating with fellow bump-side enthusiast.
Best of luck and from MA!
-Joe
1971 F-350 DRW SWB Stake Body
360 FE
C6 transmission
OEM disc brakes
OEM power steering
Dana 70 4.10 rear end
360 FE
C6 transmission
OEM disc brakes
OEM power steering
- popeyes71
from the Bay Area!
-Popeye-
1971 F-250 4x4 Highboy
- Mancar1
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
