69 Ranger 390 PS gear box, pump
Private parties only. No eBay/Craigslist listings.
67 bump
Post by 67 bump »
I did a CV swap and removed the PS gear box, PS pump and 390 frame mounts. $100 Gear box picked up in the SF Bay Area (CA) since it's pretty heavy to ship. $40 PS pump.
pchelp101
Re: 69 Ranger 390 PS gear box, pump
Post by pchelp101 »
67 bump wrote:I did a CV swap and removed the PS gear box, PS pump and 390 frame mounts. $100 Gear box picked up in the SF Bay Area (CA) since it's pretty heavy to ship. $40 PS pump.
I am looking for the gearbox and pump, do you have the brackets also? How much would it be to ship?
1969 F100, 390, 3 Speed, 2WD
67 bump
Post by 67 bump »
I've got the brackets as well, the gear box is a tank. I'd ship but it's going to be costly. Where are you located, what's the zip code.
pchelp101
Post by pchelp101 »
67 bump wrote:I've got the brackets as well, the gearbox is a tank. I'd ship but it's going to be costly. Where are you located, what's the zip code.
My zip is 76180, can you tell if the gearbox is a Bendix or Saginaw ?
pchelp101
Post by pchelp101 »
Just curious, how much was your Crown Vic front end?
67 bump
Post by 67 bump »
I paid $220 for my CV front, it's a Saginaw PS unit.
pchelp101
Post by pchelp101 »
67 bump wrote:I paid $220 for my CV front, it's a Saginaw PS unit.
From what I can search it'll cost almost that to ship that power steering gearbox
67 bump
Post by 67 bump »
Ups shows a quote of $80 to ship a 50 lb box. I'd probably go $220 shipped if shipping is around $80. The box has a remanufactured in USA sticker.
pchelp101
Post by pchelp101 »
67 bump wrote:Ups shows a quote of $80 to ship a 50 lb box. I'd probably go $220 shipped if shipping is around $80. The box has a remanufactured in USA sticker.
Thank you very much bump, found a used one locally today. Hold on to it, they are in big demand
