Morning guys...
I'm at the point where I need to start thinking about the starter I'm going to use with Sanderson shorty headers. Not sure at this point if the stock starter will work or if I will need a mini starter. If mini, which one might be a good one for under $200.
Thanks
Ron
Best mini starter for the 390FE with Sanderson headers
- Ron_Hall
1971 F100 SWB 390 FE - bored.030 over
Edelbrock Performer - Holley 600 CFI
Stock heads with some porting - Sanderson FF427 Headers
C6 with stock converter - 3.25 rear end gears
One owner...
One owner...
Re: Best mini starter for the 390FE with Sanderson headers
I've been running a Robbmc mini starter on my 428 for over 8 years with 0 problems. No more heat-soak
- mouse
i got a got a reman starter off ebay and have had no issues with it over the past year with heat soak, I also got a heat wrap for it. I had to cut the ear on the block down some so it can be clocked up position. these are pics of it I took a few week ago.
http://www.ebay.com/itm/FORD-MERCURY-SU ... xb&vxp=mtr
1971 F100 sport special 390 fe
1993 F250 4X4 ext-cab 6.9 idi
- Mancar1
Been running the same on my 68, C.S., 390 with Sanderson's last 5 years. Love it.Mach428 wrote:I've been running a Robbmc mini starter on my 428 for over 8 years with 0 problems. No more heat-soak
Keep on Trucking.......John
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
