Been researching and planning my next project, finally found a truck
picked up this 1969 F100 LWB 390/C6 about a week and a half ago. She hadn't run in 10 yrs, but I got her breathing fire again...well until an electrical gremlin popped up...now trouble shooting that.
Plan to do the CV front swap at some point. Probably an EFI/AOD swap at the same time as the CV K-member. will do a spring under conversion at least or maybe even go with 95-01 Exploder 8.8 with LSD swap.
In the meantime I just want to get her moving under her own power and enjoy her for a bit while working on more immediate needs like replacing the front cab mounts, front inner fenders, and driver floor pan.
Some near term things I will be searching through the boards for are:
1) Worth redoing wiring with an EZ Wiring Harness?
2) Best under-bed fuel tank options with with baffles, in-tank pump and driver side fill
3) Digital gauge options
4) Bench seat with 3 over shoulder belt options
So if anyone has some quick hit comments on these things let me know.
Fun..fun!
Thanks all.
Fun..fun!
Thanks all.
- 1970FordTK
Re: Been researching and planning my next project, finally found a truck
Welcome from North Carolina, looks like a good truck to start with.
from Massachusetts.
Welcome to Fordification
That is a good looking truck for sitting for 10 years, Is it the original paint or has it been repainted ?
Look forward to seeing You& Your truck onsite to see the progress.
from Ohio
1997 Honda CBR 900RR
to the best site period.
Hope you like it here.
Pull up a chair and stay awhile.
from Georgia!
- 67mann
from NY....not the city
- Mancar1
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- jimmy828
from Asheville,NC
Colorado!
2017 Ford Raptor
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
- iwhodat
Welcome from The Big Easy
Stay thirsty my friends
- MadJoe
from MA! Really nice truck, sounds like you have some excellent plans for her that I'm considering as well. Looking forward to following your progress and drawing from it.
1971 F-350 DRW SWB Stake Body
360 FE
C6 transmission
OEM disc brakes
OEM power steering
Dana 70 4.10 rear end
360 FE
C6 transmission
OEM disc brakes
OEM power steering
that's a beautiful truck, mines the same color but covered with pine needles and dirt. Its nice to see one that's still shiny and clean.
