Hello everyone, I recently bought a 1967 F250 high boy from a ranch in Stockett Montana. Really nice 83,000 mi. truck, literal barn find . I'm missing the left inside tail light cover part # 7 14W3L, the one i have is for the right side with a part # 7 14W3R I'm assuming you just replace the R with an L and thats the left side part number. Does anyone have one or know where to get one?
Thanks! Good to be on board!
1967 F250 4x4 Tail light cover
Re: 1967 F250 4x4 Tail light cover
![Welcome :wel:](./images/smilies/icon_welcome.gif)
- Mancar1
You should be able to order that part from N.P.D., David Carpenter, LMC Truck, ect.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
2017 Ford Raptor
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
Thanks for the welcome! I'll keep checkin!!
Re: 1967 F250 4x4 Tail light inspection cover
The tail light cover I'm referring to is on the inside of the bed behind the the assembly,lens,etc. It's an inspection plate i think, just a flat blank plate.
LMC, NPD, don't sell this part. Does anyone have one? or maybe just check wrecking yards around here locally.
