"Hunter"...A 1972 f350 in the making.....
Re: "Hunter"...A 1972 f350 in the making.....
so work and real life have been interfering with my progress...but hoping to achieve some gratification tomorrow...well thats about it
well got the front cap back on and the truck off to the exhaust shop...also picked up the 4 new radials w rims so now have good nice new tires all the way round....will get a bunch of pics when I get it back...hoping to fire it up in about a week and a half...any ways thats it for now
ok so here we are at pic time again....truck is back from the exhaust shop..looks great i must say...did some halfa**ed clean up on the inner fenders, they have to be replaced anyways so didnt want to waste too much time or money on them, but didnt want my engine bay all nasty and stuff sooo...and as you will see still need to do some bs repair but bettter than the bs that was there to the battery tray area for the time being...well ill let the pics do the talking
the exhaust
![Image](http://www.supermotors.net/getfile/1095640/fullsize/14183885_1233114910065981_3830790248834162555_.jpg)
extra nice n tight, had to bend way over to get this pic sorry for the lighting
![Image](http://www.supermotors.net/getfile/1095639/fullsize/14141675_1233114930065979_2517657403531517728_.jpg)
engine bay pics...i did finish painting the fenders up to the cowl but no pics same with hood hinges but ehh you be able to imagine
![Image](http://www.supermotors.net/getfile/1095636/fullsize/14079996_1234117176632421_4555059864929315928_.jpg)
![Image](http://www.supermotors.net/getfile/1095637/fullsize/14102339_1234117213299084_6746282964836620868_.jpg)
![Image](http://www.supermotors.net/getfile/1095641/fullsize/14184502_1234117123299093_8710121979753183270_.jpg)
![Image](http://www.supermotors.net/getfile/1095642/fullsize/14199628_1234117033299102_7157449784981467476_.jpg)
and the big giant hole...![Laughing lol](./images/smilies/icon_laughing01.gif)
![Image](http://www.supermotors.net/getfile/1095643/fullsize/14199753_1234117256632413_6773320758955291881_.jpg)
fresh coat of flat on the radiator
![Image](http://www.supermotors.net/getfile/1095638/fullsize/14102553_1234117336632405_8389524197588472135_.jpg)
well thats what i got for now...still need to plumb in the fuel pump, reinstall the gas tank, and fill her with fuids, oh yeah and a new alternator as well...old one while it charges is just nasty and might as well just get a new one...wife is all like "spend spend spend thats all you do is spend"...my response to this is..."Your car note is almost 700 a month so bite me!"....well should have more pics in a day or so...cheers
the exhaust
- Jacksdad
Looking good
Cast manifolds on mine, but I'm going to with a dual exhaust and turndowns too. I recently threw $40 and change at a set of dead soft aluminim Percy's gaskets to fix the constant exhaust leaks, so I'm anxious to know how it might sound when I get it all bolted up. Video with sound when you get it running, maybe?
- SeapineF37
wow
exhaust looks great. what mufflers did you go with? flowmaster series 40? bet its going to be throaty!
1972 F350 seapine green cab/chassis drw
only one who has learned much can fully appreciate his own ignorance. louis l'amour
oh yeah...forgot one more quick thing...ive never been fond of how far the bumpers stick out not to mention i just dont like the look of bumpers on anything really...so ive decided on a front bumper delete and going with a 2 piece weld in front roll pan instead....also found a pic of a truck online where someone actually made a bumpside dually bed but to carry the bump "line" around the outer fenders they used a set of chevy stepside rear fenders...looked really super sic!!...so now when i get my work van the new vision will begin but in the meantime research...first real question are there any 8 lug conversions for the crown vic front end?...some one please say yes
umm no not flows...some joe blow power sports company cant remember the name but its their own in house design, $69 a pair w/free shipping...sometime when on a budget you gotta do what ya gotta do...SeapineF37 wrote:wowexhaust looks great. what mufflers did you go with? flowmaster series 40? bet its going to be throaty!
and not sure if if I already posted this but here are the specs on the engine build...
heads...
3 angle valve job
hardened valve seats
edlebrock 50 sumptin sumptin valve springs
stainless valves
block...
bored .60 over
all sealed power bearings
sealed power speed pro pistons
hasting rings
edlebrock true roller timing set
edlebrock thumper rpm cam .292 single pattern
entire assembly was clearance checked using mics, plasti gauge or feeler gauges where applicable
factory intake
holley 750 vac sec elec choke
holley red fuel pump
np435 w/grany low
new clutch
new linkage n bushings
dana 70 rear with 3.73:1 gearing
power drum brakes![Sad :(](./images/smilies/icon_sad.gif)
heads...
3 angle valve job
stainless valves
block...
bored .60 over
hasting rings
factory intake
np435 w/grany low
new clutch
power drum brakes
ughhhh....why does all the last piddly crap take soooooooooo loooonnngggg.....anyways start up date is looking to be sept 8-9th...thats when the 5/8x18 tap and die to fix the buggered crank threads(thanks again machine shop) will be here...still have 3 busted rear lugs and rear brakes to do so i guess thatll be ok...anyways once ive got all the plumbing n wiring done ill post those new pics....so thats all for now... ![Very Happy :D](./images/smilies/icon_biggrin.gif)
sooo...progress has been extra slow...a teenage girl and her 4 friends tried to drive thu my jeep wagoneer...totaled my jeep and her car...so now im waiting on the dr's and lawyer to tell me its ok to be out in the yard working on my truck...ill try and at least get some pics of what little i have gotten done and pics om whats left of my jeep just for giggles later tonight...well thats all for now
ok so well got the old ford fired up finally, had a definite very loud tic that i determined to be the #5 exhaust lifter....so now im running 7 edlebrock lifters and one melling...still trying to get timing where i lke it and the holley is running a tad rich and choke still isnt quite happy...however im changing the trucks name to "Rumpity Steelskin"....being as thats the beastly sound coming from underneath...this rumpity rumpity sound...I will try and figure out how to get the vid posted....any ways....thats all for now
- basketcase0302
Kool you got it fired up! Lifters can be such a PIA!
Beauty of the Holley though is how easily they can be rejetted and how simplistic they are to work on. Always loved them on road but off road they are the worst for float issues causing flooding, (even the center hung Holleys I messed with were so temperamental with flooding off road).
Shameful how many folks let our inner fenders under the batter rot away...![Sad :(](./images/smilies/icon_sad.gif)
well...quick update...motor ate the cam at about 10hrs of run time...at this point im a lil frustrated, and xmas is hot on my heels so the all roller valve train will have to wait a bit....but definitely wont be going back with a flat tappet cam...well thats all for now
well I found an all roller kit that includes cam, lifters, timing set, pushrods, valve springs, retainers, and locks for 1200.00 smackeroos...in a nice thumpity 291/311.....soooo...ssavin up a few bucks then gonna send my block up to Tennessee to have the next stage of machine werk done...well thats all for now
- basketcase0302
I always wanted to go to a roller but just never did...
Bet that's gonna have a real nice thump to it.![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
