Got a new farm truck.
I just brought home a new family member. "Buck" is a 1971 F-250 4WD Flatbed Dually(Factory Styleside) with a 360 and 4-Speed. I am the 3rd owner and the first 2 were next door neighbors. Buck spent his first 40 years on a farm in Northeast Oregon. He is Sky View Blue over Wimbledon White with a code 2 (not on the '71 decoder) Lt/Med Blue interior. Somewhere along the way the homemade flatbed was added along with the homemade front winch bumper with an 8k Ramsey. The duals were an aftermarket kit add-on. The odometer shows 72k. I have no idea if it has been around but there is a good chance it has not given where it has spent most its life. Yes, I know the grille is from a '72. I am already looking for the correct inserts. I also need some Dietz 77-533 clearance lamp lens and gaskets, a cigar lighter, a pair of hood hinge springs and the right side trim for the fender, door and cab corner. I look forward to putting Buck to work and sharing on this great site.
1971 F-250 4WD Flatbed Dually(Factory Styleside), 360, 4-speed
- idaho_cowboy
Re: Got a new farm truck.
Really good looking rig there. And welcome!
Would love more photos!
So the duals were a aftermarket drum / wheel set-up for the Dana 60?
When you look for hood hinge springs, look for the square springs, as opposed to the circular. They are stiffer and in my opinion work better / last longer.
Best!
- Joseph
Best!
- Joseph
Owner @ bumpsidetreasures
The dual conversion came from Arrowcraft Products, Inc. They are still in business arrowcraft.com. The kit parts list I found in the glovebox says it came with 2 adapters, 2 fenders, 4 one ton dual wheels and 16 lugnuts.
Thanks for the tip on the springs.
BTW... this forum has already helped me out. I couldn't find the jack handle. Found a post telling me exactly where it is. Rather where it is supposed to be. Sadly the handle is gone but at least the mounting brackets are there.
- Mancar1
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
![Welcome :wel:](./images/smilies/icon_welcome.gif)
- ok68crewcab
2017 Ford Raptor
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
- SeapineF37
welcome from sunny florida. nice ride. good to see other hardworking flatbeds
and the winch bumper ![Cool 8)](./images/smilies/icon_cool.gif)
1972 F350 seapine green cab/chassis drw
only one who has learned much can fully appreciate his own ignorance. louis l'amour
Buck has his own Facebook page. https://www.facebook.com/buckthe1971f250/ I will see if I can keep up to date with all of his adventures.
- 1970FordTK
Welcome from North Carolina. ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
