cab, bed, rear axle
Private parties only. No eBay/Craigslist listings.
Bill Ramsey
cab, bed, rear axle
Post by Bill Ramsey »
I have a cab from a 1969 F250. there is very little rust.
None in the floors or drip rail.
some in the lower cab corner underneath on right side. cant see unless you under the truck, other that that, it is solid as they come.
it has a cracked windshield with the trim, and a slider back window still on it.
$500 firm, no paperwork comes with this. No other parts available at this time.
I can help load it with a tractor.
Rear axle from a 69 Camper Special. This has the larger drum brakes and 3:54 gears. (Axle code 37, Dana 60) $250
Core support from a '72 good shape $50
'69 bed, no rust but left side and tailgate are damaged. $100
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
1962 Fairlane 500 Sports Coupe
VW Sandrails
Honda ATC's
36' Diesel Pusher for roughing it.
colnago
Re: cab, bed, rear axle
Post by colnago »
What is included with the rear axle? Hubs, drums, etc. Any photos?
Joseph
Beat98TJ
Post by Beat98TJ »
Location?
I can break a steel ball in a rubber room.
Bill Ramsey
I am in Ramona, Ca. about half hr east of Escondido.
the rear axle is complete, came off a running and driving truck. a return spring or something is loose inside one of the drums, it was easier at the time to just replace the whole thing with another one I had.
Pics are here:
http://sandiego.craigslist.org/nsd/pts/5427727826.html
Thanks.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
Bill Ramsey
still have all this.
Cab $300
also, gas tank, $45
front fenders $45 each good shape.
Let me know. can take to work in Chino (not the cab, too big).
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
Jacksdad
Post by Jacksdad »
I saw your post on Craigslist back when you first advertised it - I just wish I'd known about the cab before I started welding mine up. I'm in San Diego and it would have saved me a bunch of time :roll:
I know a couple of guys locally with bumps - I'll put the word out for you.
C7TZ
Post by C7TZ »
Do you still have the core support?
Bill Ramsey
C7TZ wrote:Do you still have the core support?
Yes, I do.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
Bill Ramsey
Rear end has been traded off for shiny stuff.
top of cab is gone, anyone need patch panels? floor is good.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
KulpFarm
Post by KulpFarm »
Are rockers in good condition? How much shipped to 19438.
Any inner cab corners
Bill Ramsey
Here is some pics of the cab parts.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
Bill Ramsey
More.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
Bill Ramsey
yup.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
