Complete ignition setups
FORDification
Site & Forum Admin
Site & Forum Admin
re: Complete ignition setups
Post by FORDification »
As long as the stock points-type distributor is in good shape, about all I could offer is to replace the points with a Pertronix unit (with matching coil).
Or you could get a factory electronic ignition from a later truck, which is what I'm planning on doing. Future parts replacements will be much easier when you can go into any parts store and get what you need off the shelf.
Billybobjunky
Post by Billybobjunky »
so...how good of a setup would the original '77 set-up be? the electronic dizzy and spark module box?
1967 SWB 2wd F100
-'77 V8 [[[410]]]
-'74 C6
-Re-wired main harness
-Disc Brakes/Power Steering
FORDification
Site & Forum Admin
Site & Forum Admin
I've heard nothing but good things about the Duraspark setup, reliable and inexpensive, which is why I'm going with it over a Pertronix. That, and I get to keep it all-Ford under the hood.
Billybobjunky
Ok, lets say that this is a happy world and cross-breeding doesn't cause rage and hate. How do you feel about this one? http://www.carbdford.com/tech/HEI/hei.htm This is very economical, and easy to setup, so it seems like a winner to me. What do yall think about it?
1967 SWB 2wd F100
-'77 V8 [[[410]]]
-'74 C6
spartman
Post by spartman »
Saw that article myself.
Was thinking about doing that since I had a spare chevy module laying around.
Just need the dizzy.
FORDification
Site & Forum Admin
Site & Forum Admin
I wouldn't have a problem with that. I don't see why it wouldn't work just fine....(but I still think you should keep it all Ford!) ;)
binder56jd
Post by binder56jd »
BBJ- good article- thanks for the link- somewhere i had a link for some aftermarket ford hei dist. selling for around $100. - i'll keep looking-jd
http://www.musclecarsusa.com/shop/distr ... page1.html
now serving #235
binder56jd
FORD 351C & BBF HEI DISTRIBUTOR
$199.99 $99.99 Our Price!
HRI 5002002
We have these brand new high-performance HEI (high energy ignition) - no rebuilt components by IGNITION PLUS. Great replacement for non-HEI distributors. All you do is remove your resistor from your "points" distributor lead and run 12 volts to this coil. Yes, that simple! Comes in black, red and blue color distributor caps, we reserve the right to ship what cap is available at time of shipment. Add $5.00 for specific color cap. 5 year warranty excluding the cap and rotor.
http://www.hotrodsusa.com/store/ignition.html
now serving #235
Billybobjunky
Thanks for tracking that down JD, I saw it awhile back and knew it existed but lost track of it. Well I gotta say guys, I think that one set-up I referred to earlier is the way to go. I went and bought all the components today, dizzy, module, and coil for just at $74 bucks. I had a $20 autozone card, so that helped but still, without it, $94 bucks for one heck of an ignition system! After I get it all put together, I'll let yall know how it goes! Thanks for the input.
1967 SWB 2wd F100
-'77 V8 [[[410]]]
-'74 C6
binder56jd
good deal bbj- i'm sure it will work fine - have seen several articles regarding that setup-jd
now serving #235
460 crew
Post by 460 crew »
Billy, congrats on the new ignition for the killer price!
JD
I had bought one of those procomp HEI dizzys for my 460 but can't use it because the thermostat housing is in the way with the huge cap they have nomatter if you use the 90 degree or vertical. I also bought one for my buddies 351M and it fit great and he says it's running better with it on there and no more wires everywhere. I think I might have one more thermo housing to try that has an indention on the side, might work.
binder56jd
460-does DUI have those thermostat housings available for the 460?- glad to hear the part about the 351! thanks jd
ps- is this what u need
http://www.pricemotorsport.com/html/bod ... using.html
now serving #235
