70 F100
Re: 70 F100
from Massachusetts.
- 1970FordTK
Re: 70 F100
Welcome from North Carolina.
Re: 70 F100
Colorado!
2017 Ford Raptor
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
- HIO Silver
Re: 70 F100
Nice color and stance.
But the proportions seem off.. as if it was a long bed truck but cut down to a shortbed wheelbase and the bed, rear of the wheel openings, was left long.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
Re: 70 F100
Yes. Bed was cut down...and yes, The rear of the wheel opening is a little longer than a short bed.
1970 Bump
- Mancar1
Re: 70 F100
What matters is it is a killer looking truck and U love it....Keep on Trucking....JohnBadApp13 wrote:Yes. Bed was cut down...and yes, The rear of the wheel opening is a little longer than a short bed.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Re: 70 F100
Pretty truck and very well restored! I am VERY curious about those clear front side reflectors. I haven't seen them before. Where on earth did you find them?
1953 F100 (Waitint for attention)
1969 F100 LWB w/ 72 grille (Daily driver & work truck)
1969 F100 LWB Parts truck
1971 F100 SSWB 4x4 (Current Project)
2016 Jeep Wrangler Unlimited Sport (Actually the wife's)
Re: 70 F100
I am pretty sure they came off of an 18 wheelerWilfred of Ivanhoe wrote:Pretty truck and very well restored! I am VERY curious about those clear front side reflectors. I haven't seen them before. Where on earth did you find them?
1970 Bump
Re: 70 F100
18 wheeler eh? A 67 to 72 I assume? I've only seen the 1+ ton fords.
- fireguywtc
Re: 70 F100
from Alabama!
Bill
