I currently have a 71 F100 4x2 with a 302 5.0 with a 3 speed granny floor shifter I recently purchased. The truck itself is in good shape but definitely needs add'l maintenance but first things first. While in reverse the shifter pops out of gear into neutral. But if I keep enough pressure on the shifter while in reverse it will stay in gear. The previous owner used the truck for track racing and there are mods such as the steering column which is not factory original. I've already replaced multiple parts including the front brakes with a Master Brakes disc kit, dist, water pump, carb, etc. but it's just a start. Eventually I plan on replacing front suspension & the Holley 2 barrel with a 4 barrel intake n carb and possibly the engine with something more powerful. Before doing
any further repairs/upgrades I wanted to first consult with the experts. Living in the DC area it's hard locating a shop with the expertise of u gentleman. Much Respect!!!
Thanks for the add. Any advice would be appreciated
