3 Speed Power Steering Column
Private parties only. No eBay/Craigslist listings.
Hawkrod
Post by Hawkrod »
I have a complete three speed column with shift rods and trans levers from a 73. Bolts right into a 67-72 that has Saginaw power steering. This is fair shape with nothing broken but it is as pulled and will need to be cleaned up. $250.00 plus shipping. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
Bob67f100
Re: 3 Speed Power Steering Column
Post by Bob67f100 »
Do you still have the power steering column? I realize that your post is two years old, plus.
Hawkrod
Post by Hawkrod »
Hello, thank you for the inquiry. I am sorry I did not see your response as I have not logged in for months. I did sell the column but now I have a 77 column if you are still looking. It is pretty much the same thing but they revised the shift rod ends and the rubber boot at the firewall. It is a direct replacement for a 67-76.
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
