Parts Run
- themoldfords
Parts Run
I am heading to the local parts warehouse (junk yard) this weekend, anybody looking for anything in particular? I will pull parts and ship them for a marginal markup if I find what you are looking for.
Tim
____________________________________________________________________
'69 F100 240, 3 spd (used to be column shift), '05 F150 wheels, cougar buckets, Hurst floor shifter, '78 discs, power steering and column
"Your responsibility to be ready for the fight never ends" - James Yeager
Re: Parts Run
I'm looking for a 69 ranger grille in good shape. And Big f series fenders for a slick body style truck if they are with in reason
- themoldfords
Re: Parts Run
You do realize that shipping will cost a fortune on those large parts going from my coast to yours? Are you looking for 600 style fenders?
Tim
Re: Parts Run
The fenders are for the f600 but not for a bumpside body looking for slick fenders. To bad we couldn't get a quote on shipping beforehand that would be the deal breaker.
- patrickdotryan
Re: Parts Run
Tim, if you find a black plastic boot that goes between the brake booster and firewall, I'm looking for one of those. Like the one in the photo in this post a little way down.
http://fordification.com/forum/viewtopi ... 2f1331e6d7
Thanks Tim. Patrick
Thanks Tim. Patrick
1971 F250 Custom
Camper Special
Prairie Yellow
390 (was a 360), C6 Auto, Dana 60
Camper Special
Prairie Yellow
- themoldfords
Re: Parts Run
I will do some looking.
Tim
- themoldfords
Re: Parts Run
I did some looking last weekend and found a couple donor trucks at the local yard. patrickdotryan, I my have found you a boot, I will have to look at it again this weekend when I take some parts and will let you know. Any body else looking for something in particular?
Tim
- patrickdotryan
Re: Parts Run
Ok. Thanks Tim. Let me know. I haven't put everything back together but it would be good to have that boot in there. Cheers, Patrick
1971 F250 Custom
Camper Special
Prairie Yellow
Camper Special
Prairie Yellow
- themoldfords
Re: Parts Run
Patrick, I wasn't able to get anything as all the parts I went back for were gone.
To everyone else out there looking for some parts. I just picked up a '68 F100 long bed, 240/300, 3 speed, column shift parts truck over the weekend. I will be removing some parts for myself and selling everything else off. Let me know what needs are out there. I will for sure be hanging on to the driver's fender and the bed. I should be able to get some good pics this weekend.
Tim
- themoldfords
Re: Parts Run
![Image](http://s79.photobucket.com/user/timshelgren/media/IMG_0727_zpsikfujpad.jpg.html)
The parts truck is the one without the hood.
Tim
- patrickdotryan
Re: Parts Run
Thanks Tim for looking. I did end up finding that part so no problem. Cheers, Patrick
1971 F250 Custom
Camper Special
Prairie Yellow
Camper Special
Prairie Yellow
Re: Parts Run
Tim
I am looking for a complete (distributor,coil,harness,module and plug wires) for a 300 6cylinder.
- themoldfords
Re: Parts Run
Blackwater,
When I picked the truck up it would not crank, I would want to be sure all those parts are in working order before I sell them to anyone. I will do my best to play with it Friday to see if I can get her running. I need to get the hood on before it rains anyhow.
Tim
Re: Parts Run
I should have said electronic ignition. Ford Duraspark.I want to change from points using all Ford parts.
Thank You!
Thank You!
