In need of a new radiator
I have a 1969 Ford F-250 A/C 3 on tree with the 360 v8. It over heats since I still have the original 1969 radiator. I just received a new 100% aluminum one from Vista auto parts but mounts are on the rear of radiator. Mine are on the front with fan shroud on the rear. What do I need to order? I read in an Advance Auto comment that my truck had 3 different radiators that year. I already cleaned the full system with radiator cleaner and removed radiator to clean fins and blow dirt out of fins. Inside radiator looks pretty rusty but after 46 years I can understand. I am leaving the A/C condenser in place since my intention is to keep truck as original as possible.
Re: In need of a new radiator
First off, welcome to the site. I suggest you post your needs in the "Parts Wanted" section on the bottom of the page, you will be much more successful in locating what you need.
In retrospect, I have an extra operational radiator from a 70 F250. PM me if you need more info.
2017 Ford Raptor
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
- Mancar1
Welcome aboard from Tehama County, Ca.
Sometimes it can b a pita finding certain parts for these old trucks, but the hunt is part of the fun.
Keep on Trucking........John
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- fireguywtc
from Alabama!
Bill
