I'm getting ready to do a tranny & t-case swap on my 72 F100. I can use a T-18 and an NP205 out of a 79 Bronco I recently acquired, or convert my NP435 to 4wd if I can find the parts and bolt the 205 to it.
From the info I have been able to find, it appears that it would make little difference in strength and functionality, and it appears that the 2 combos would be the same length so there would be no difference in drive shaft lentgh needed.
My question is do the two tranny's share the same crossmembers and mounts?
Thanks
NP435 / T-18 compatability
Re: NP435 / T-18 compatability
Are you sure its a T18 ?
I believe a '79 Bronco should have come with a NP 435.
Almost positive it is a T-18.
I haven't actually seen the truck yet as I am working overseas, the seller sent me pics of it though, it says Borg-Warner right on it, and if I remember right he said the door tag code indicates a T-18.
- Hawkrod
Yes 70's Fords can have a Borg Warner or a New Process trans. Neither is unusual and they are directly interchangeable. You can also use a later T19 with synchro low.
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
