Im looking for someone who has the trapeze style linkage that I can buy. I have a 71 F-100/ 360 2 bbl. carb./auto trans.
Anyone that can help please let me know.
Trapeze linkage
Re: Trapeze linkage
i saved a couple of those accelerator linkage parts but I may not be able to find one. I will look and if I find one i'll post here.
jim
jim
Re: Trapeze linkage
This came off a 72 360 2v iirc . maybe someone can confirm. Sent you an email
Re: Trapeze linkage
Thanks Jim but 71 cc had exactly what I needed.
I was hoping that the banana was part of the deal!
JV
JV
Re: Trapeze linkage
i found one. it is off an FT engine . 2 ton truck. much heavier . the bolt pattern for the throttle bracket is the same on the FT manifold as the FE so it will fit.
jim
jim
Re: Trapeze linkage
I did away with this ridiculous contraption and made my own rod. It is amazing how much more driveable the truck is now without all the slop in the linkage.
1967 F-100 4x4 custom cab.
Re: Trapeze linkage
i have never seen one on a ford pickup that was not wore out. i don;t have a truck with that POS on it either. it was not one of ford's better ideas.
jim
jim
Re: Trapeze linkage
Somewhere there must be an exact length cable that will directly replace the original linkage. It's just a matter of stumbling across it. The older ford pickups had a cable by the way.
