Same size tires on 4wd.
- hdpusher
Has anyone actually measures the circumference or their tires to make sure they are all 4 the same size? On top of that what is an acceptable difference? I checked mine today and from smallest to largest is 1 1/2 inches.
67 Chevy II 302 sbc
67 Ford F350 Motor home
68 Ford F100 long bed (Sold )
78 CJ5
03 Dodge Cummins
78 CJ5
03 Dodge Cummins
Re: Same size tires on 4wd.
If you're driving on a hard surface in 4wd you "should" have the same make ,size and wheel width on all 4
Drifferent brands can have different circumfrence. and a wider rim will shorten a tire.
If you're going through loose stuff it's not as critical .
for road travel you'll want the same tires on each axle.
If you have the wrong combination you will really notice it on dry pavement , because it won't roll very good.
- 1 Crummyshooter
I always tried to get the best match side to side, and if there is a bad mismatch, put it on the front, cause it's only pulling when it is expected to spin some.
Due to the high cost of ammunition, you can no longer expect a warning shot.
When someone was beating on my door hollering "Alcohol, Tobacco, and Firearms", I naturally assumed it was a delivery.
- hdpusher
All 4 tires bought at the same time, stock rims, rotated on a regular basis, tire pressure the same and the diameter was checked when the tires were off the truck. I did not experience the "chugging" (as I call it) when driving on dry pavement in 4wd as a result of the tires not being the same size or under inflated. Is 1 1/2 inch or more acceptable?cep62 wrote:If you're driving on a hard surface in 4wd you "should" have the same make ,size and wheel width on all 4
67 Chevy II 302 sbc
78 CJ5
03 Dodge Cummins
78 CJ5
03 Dodge Cummins
- hdpusher
Good point on it pulling.1 Crummyshooter wrote:I always tried to get the best match side to side, and if there is a bad mismatch, put it on the front, cause it's only pulling when it is expected to spin some.
I was thinking of putting the oversize tire on the pass side rear since it starts to spin first. BUT then again if its larger I guess the drivers side would spin first
67 Chevy II 302 sbc
78 CJ5
03 Dodge Cummins
78 CJ5
03 Dodge Cummins
If you put mismatched tires on one axle you can burn up your pinion gears.
It'll think you're always turning around a corner.
