Hello All
Just picked up a 68 F250 4x4 360 4spd with just a tick over 52K on the clock over the weekend with no rust that runs and drives great with everything working, except the climate controls. The truck has a Dana 44 12 bolt knuckle up front and what I think is a Dana 70 in the rear. Need to get the numbers off it to confirm it though. When I get the numbers I wish I had the door tag to confirm the axles are original but that was gone with the repaint of the truck and never replaced. The rear has the leafs with helpers and stops on the frame with the correct shock mounts so I think it was original. Anyway look forward to enjoying my time here.
cstoyer
New Member 68 F250 4x4
- cstoyer
68 F250 4x4
Re: New Member 68 F250 4x4
from Massachusetts.
- 1970FordTK
Welcome from North Carolina.
- popeyes71
from California!
-Popeye-
1971 F-250 4x4 Highboy
- fireguywtc
from Texas!
Bill
- Mancar1
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Colorado!
2017 Ford Raptor
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
