Starting with out clue
Hello everyone, just picked up 1971 f 100 and just want to start off by fixing a couple small things. My first small project is to get the turn signals to work. The passenger side works inside and out but the driver side rear dosent doesn't work and the front comes on but doesn't blink. The emergency blinkers all work except for the rear driver side and the interior left dash dosent work.
- jimmy828
Re: Starting with out clue
from Asheville,NC. I hate messing with the electrical parts of any vehicle. Good luck with your's.
from Massachusetts.
Colorado! And everyone STARTS with out a clue, no worries!
2017 Ford Raptor
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
- fireguywtc
from Alabama!
Bill
Well I
Just changed the bulb and the turn signal works. The blinker on the dach is clicking but the lighted arrow is not. Also found out that
My dash lights don't work. Ilol take a
Look at That tomorrow.
- Mancar1
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
From Phoenix, AZ
It starts Small, Before you know it you have it completely disassembled and replacing parts you didn't know existed.
"I ain't as good as I once was But I'm as good once as I ever was"
https://photos.google.com/photo/AF1QipM ... mfKhMOFcFj
1971 F100 SWB 302 2WD (Work In Progress)
2010 F250 4X4 6.4 Power Stroke / lariat Black
2020 F150 4X4 3.5 Eco Boost / icon Silver
- jimmy828
Well saidAZf100 wrote: From Phoenix, AZ
- flyboy2610
And soon you have parts all over everywhere! And you stand there wondering "How did THAT happen?"
Take lots of pictures, and get a big box of slider closing storage or freezer bags in various sizes, and label them with a sharpie as you take things apart. Trust me: you will not get it back together as soon as you think you will, and few things are as frustrating as looking at a pile of bolts wondering "Now where did these go?"
Welcome to the board. Don't be afraid to ask questions, even if you think it's a basic question everyone should know the answer to. We're here to help!
Red Green
you'd better be right.
Red Green
- 76Kroh
from AZ
I had similar issues with my blinkers. Replaced the whole blinker assembly in the column everything works great now.
1968 f100 LB 360 4-speed manual
- hdman90
from Pennsylvania! Good luck with the lights, it always seems to be easier than it sounds... I know I always dread it and then it ends up not being so bad!
Ok. Just so everyone knows I'm from Ohio. Started to pull the instruments dash out to check the bulbs but can't get it out far enough to see the back side. The speedometer cable has no play in it. If I remove the speedometer cable is there anything I need to know before I disconnect? Thanks again for helping out.
