1969 f250 turn signal column issue
Hazmat6750
Post by Hazmat6750 »
Does anyone have the wire diagram for the turn signal mechanism in the steering column? Flashers work but no turn signals. My arms getting a workout and the weather is warm but I sure would like to fix this issue. Any help would be great!!!!
Thanks,
Carl
1969 f250 4wd
390 crate motor
Madman
Re: 1969 f250 turn signal column issue
Post by Madman »
I'm sure there is an answer to your question, but you are better off in the electrical forum, here you are in the "Welcome" Forum. I'm positive someone here will be able to help you out!
and by the way, :wel: Colorado!
2017 Ford Raptor
1975 Ford Bronco
Mancar1
Post by Mancar1 »
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
fireguywtc
Post by fireguywtc »
:wel: from Alabama! :fr:
Bill
lennyp
Post by lennyp »
:wel: from Massachusetts.
