I made a batch of 10 of these support struts for our highboy's, to keep the dana 24 from swinging back and forth under load as they commonly do. Made them quite a while ago now, and sold all but one to members of this forum. Then i pulled my personal one off after switching to a np205 transfer case, so i have these two struts that i just dug up while cleaning the garage out.
The support strut, sandwhich rubber and plate are there for each one, just missing hardware (bolts, nuts, washers, etc.).
You may notice in the picture one has a .120 wall stub tube and the other .250. This is just because the on that was on my truck got made at a different time than the batch i made. The .120 wall one is more than strong enough.
$40 shipped each.
Dana 24 Support strut for Highboy
- 1971ford
Re: Dana 24 Support strut for Highboy
Need these. 4074899207
1967 f250 6bt Cummins, Dana 60 front, 14 bolt rear, np205 divorced.
1985 Mustang SVO Sage green, big turbo, aluminum big valve head, 03' Cobra IRS.
1986 Mustang SVO medium caynon red metallic, Stock
