newbie transmission question
I have a 72 ford f100 with 360 engine three speed its a project to reconnect with my dad. My transmission gave out and want to add a 5speed anyone know what I can swap it with and do I need to get it with the bellhousing. Can someone help please I will really appreciate it thanks.
- HIO Silver
Re: newbie transmission question
Sure. Visit http://www.moderndriveline.com and spec a short-shaft, 10-spline TKO 500/600. The shortshaft allows ya to use the stock bellhousing.
You'll also need a shifter, boot, shift ball, reverse lite pigtail, speedo gear, and maybe a new trans mount. Also needed is a 31-spline output yoke but likelly shortening of the coupling shaft is required anyways so source one from a longbed with an FE/C6 combo and it fits perfectly. Add a clutch if yours has more than 40k miles.
Reposition the trans crossmember accordingly.
Total cost is about $3,000..... you can handle that, right? Visit my build thread linked in my signature below if ya want more details.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
This is pretty much one of the simplest swaps. http://www.fordification.com/tech/M5R2_5spd-swap.htm
Thanks for info hitting the junkyards this saturday 50percent off at pick a parts.
- HIO Silver
Keep in mind that what may appear as a good deal at the JY may not be a good deal. Do you best to look for a low mileage candidate and keep your fingers crossed that it was lightly driven by an elderly man or woman..... There is a reason there are lots of esses in "Tran$mi$$ion$".kurupt72 wrote:Thanks for info hitting the junkyards this saturday 50percent off at pick a parts.
68 Mustang
65 Mustang
68 Mustang
65 Mustang
- eggman918
I always plan on a bone yard trans as a core if when i get it home and look it over closely and it turns out to be a runner then I'm real happy and if not the Wife has already budgeted for an overhaul
I pulled mine out of a wrecked '92 and it looked,sounded and felt good at the yard but it ended up needing an overhaul I did the overhaul myself and it was not too difficult and ~$400.00 in parts I used Southwest gear in El Paso TX. They have a good well illustrated manual and there prices were very fair.
Plan for the worst and hope for the best....
Good luck,
Steve.
Good luck,
Steve.
