Changing Gear Ratios: What Would I Need?
colnago
Post by colnago »
I have a '67 F250 Camper Special with a 4.10 or 4.11 rear end (sorry, I think it's a 4.11, but I don't remember for sure). What would I need to change it to 3.73 or 3.54? Just the ring and pinion? The whole rear diff? Would it be easier/cheaper to find a different rear end in a junk yard, and swap the whole thing?
Thanks,
Joseph
Re: Changing Gear Ratios: What Would I Need?
You just need the ring and pinion gears. Might as well but new bearings and seals in while your at it. Do yourself a favor and find a rear end shop to set your gears, you'll be glad you did. Pull the chunk, take it to them and let them set it up correctly. I did mine and I'm not sure it's 100% right but I'm rolling the dice. :hmm:
tac
Post by tac »
If you are going to learn how this is one of the easiest to do. In addition you will also need shims to set pinion depth, a new crush sleeve and a dial gauge to set backlash. There are rebuild kits that have all the bearings, shims, gaskets, seals and some Prussian blue to check gear mesh pattern.
cep62
Post by cep62 »
sargentrs wrote:You just need the ring and pinion gears
Not with a Dana 60
you will also need a new carrier.
I think it's a 3.90 and up take a different size .
There might be a shim to put under the ring gear to help some applications. :hmm:
colnago
Post by colnago »
cep62 wrote:you will also need a new carrier.
I think it's a 3.90 and up take a different size.
Rats! That's what I was afraid of! Oh, well, better to find out now ...
Thanks,
Joseph
Mancar1
Post by Mancar1 »
I agree with Sargentrs on doing yourself a favor.
Since my shop and myself are not set up for it. :lol: I am going to take mine to a rear end shop.
68 CS with the 4:10. I am going with 3:54.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
cep62
Post by cep62 »
colnago wrote:Rats! That's what I was afraid of!
Don't let that scare ya ,it's just the carrier not the whole case.
I don't think they're all that expensive.
Or maybe just swap a used assembely ?
dftuttle
Post by dftuttle »
A gear change in the Dana 60 is more difficult than the 9 inch but totally doable. Spicer(Dana) has the instructions on their website. They say you need a bunch of specialized tools to properly set the pinion height in the housing. I found most of them in Ebay for a decent price. The thing I haven't got is the housing spreader. The spreader makes it easier to push the carrier in & out while shimming the carrier side to side. This shimming is needed to set gear engagement.
I did find this link if you really want to try yourself. It has a good explanation of the process & doesn't use the special tools.
http://dana60.com/gears.html
If common sense was really common, wouldn't everybody be using it?
gregamorton
Post by gregamorton »
on dana 60s is 4.10 down and 4.56 up for swaps. So 3.54s and 3.73s will work in the 4.10 rear. I would not use any thing but a 3.54 if spending the money to change it all out.
1967 mercury F350 7.3 IDI ats turbo kit c6 gear vendor overdrive 3.73s rolling on 19.5s
1971 sport custom on 1979 f350 highboy frame 460 c6 np205 dana 60s 3.54s
1974 F100 baby blue & rust 240 3 speed 3.70s sitting on the ground!
1990 F250 extended cab FI460 e40d 3.55s daily driver
Possibly looking for my next bump right now!
cep62
Post by cep62 »
cep62 wrote:Not with a Dana 60
gregamorton wrote:on dana 60s is 4.10 down and 4.56 up for swaps. So 3.54s and 3.73s will work in the 4.10 rear
I think ... I musta been thinkin bout Dana 44.
Correct me if I'm wrong. :oops:
Not with a Dana 60
My bad. Didn't realize it wasn't a 9". :oops:
