Parting out a 1967 F100 4x4
Private parties only. No eBay/Craigslist listings.
irish_4
Re: Parting out a 1967 F100 4x4
Post by irish_4 »
Are the doors available? Are they in good shape?
1970 F250 Custom 390FE
2007 F150 FX4 5.4 3V
HardOnParts
Post by HardOnParts »
If you cut the center out of the dash I would be interested in the left side from the column to the kick panel if it is not rusty.
towtruckerfour
Post by towtruckerfour »
Does the truck have body moulding? I'm looking for the hardware to put mine back on?
Troy
DirkD_67F100
Post by DirkD_67F100 »
Hello. What shape is the bed in? Do you have a price in mind?
Thanx
jreb333
Post by jreb333 »
I need an automatic shift column thats good and tight (low or no endplay slop) and anything for front disc brakes if by chance a PO did the conversion
JESUS LOVES YOU! everyone else thinks your a jackass!
HomesteadTruck
Post by HomesteadTruck »
What size motor? If 300, do you have fuel line from pump to carb?
CharlaineC
Post by CharlaineC »
do the horns work and do you have the wiper res and pump? also do you have the jack and spare tire holder. what condition is the bench in i'm in spokane so we could met on blanchard rd
mdbaker42
Post by mdbaker42 »
I need the z-bar assembly soup to nuts. Frame mount, block/bell housing mount and everything in between, including all hardware.
