Plum ugly sentenced to be shot...
Camper Special
Re: Plum ugly sentenced to be shot...
Post by Camper Special »
Beauty is in the eye of the beholder. :wink:
I think we are beholding to you for sharing your pictures and progress. :thup:
Out of order, I show you out of order. You don't know what out of order is, Mr. Trask. I'd show you, but I'm too old, I'm too tired, I'm too [censored]' blind. If I were the man I was five years ago, I'd take a FLAMETHROWER to this place! Out of order? Who the hell do you think you're talkin' to? I've been around, you know?..And Harry, Jimmy, Trent, wherever you are out there, [censored] YOU TOO! - Lt Col. Frank Slade
1972 F100 4x4 Calypso Coral
1970 F250 H/B Harbor Blue
1970 F250 CS Red
1970 F250 H/B Yucatan gold I'm back!
FREEHAND
Post by FREEHAND »
Thanks guys I appreciate it! For now the bumper will get painted when I paint the rest of the truck. It was a pretty easy job, took me about 3 hours start to finish (even with a lunch break in there).These two relatively small mods front and back have really helped to tighten up the look of the truck a lot and I have been able to do them with almost no expense, so that's a good thing! I'll post some more pics when I get the roll pan sides made and welded up to see what the finished product looks like.
390bump
Post by 390bump »
if you want a tip... straight primer wont hold up very long... mix in a bit of compatible black paint with the primer.
FREEHAND
Post by FREEHAND »
Will do 390, Hopefully it won't be in primer for too long and I'll be able to get into a coat of UV resistant topcoat sooner than later. I really like the "sheen" of SEM trim black so I am shooting to be able to do that before long.
pincheweddo
Post by pincheweddo »
FREEHAND wrote:Thanks guys I appreciate it! For now the bumper will get painted when I paint the rest of the truck. It was a pretty easy job, took me about 3 hours start to finish (even with a lunch break in there).These two relatively small mods front and back have really helped to tighten up the look of the truck a lot and I have been able to do them with almost no expense, so that's a good thing! I'll post some more pics when I get the roll pan sides made and welded up to see what the finished product looks like.
You can save a ton of money using Valspar Anti Rust Armor (at Lowes) and a foam roller for paint. If you take one of those body panels down to Lowes they will match the color on your truck so you can keep the plum. :thup:
See project updates at:
http://1967f100.blogspot.com
FREEHAND
Post by FREEHAND »
Thanks pincheweddo I'll have to look into that, looks like it'd be good for the frame and back side of panels. I think I'll stick to black though... lol
FREEHAND
Post by FREEHAND »
Got some more work done, heres the finished roll pan. Not a bad end result for "recycled" parts.
Before welding it in...
FREEHAND
Post by FREEHAND »
And after...
Nice clean look!
FREEHAND
Post by FREEHAND »
Its been a while since I've posted but I have finally been able to get some more work done. I ended up pulling the front end and replacing the radius arm bushings and the axle pivot bushings (that was a job). I cut the front coils to lower it about 2 inches in the front and flipped the front leaf spring shackle in the rear to get the back end out of the clouds. It looks a million times better than it did and that was an exciting step in the right direction. Now I just have to make a set of steel angled spacers to weld on the leaf spring pads to get the 17 DEGREES of pinion angle correction I need. After that it'll be drive-able and one big step closer to being done. I'll try to get some pictures later this evening.
motzingg
Post by motzingg »
wow nice work on narrowing the bumper. totally one of those 'why didn't i think of that' things!
my bumper is 'going black' eventually, too, i'll have to borrow that idea from you when i do.
pedro69ford
Post by pedro69ford »
im a big fan of the flareside,your doing a jam up job freehand,keep those pics coming.
Heirloom
Post by Heirloom »
NIce work man. Keep it up! :thup:
~Heirloom
~ Thomas Jefferson
~ Abraham Lincoln
sykanr0ng
Post by sykanr0ng »
If you want a rather flat black that will last longer take a look at John Deere Blitz Black it is a farm/construction equipment paint so it is meant for outdoor use.
... I've got skills, ingenuity and no regard for maintaining any kind of historical preservation/authenticity...
FREEHAND
Post by FREEHAND »
Thanks for the compliments everyone, its reassuring in the middle of a build. My truck is a far cry from a lot of the amazing ones on this forum and its nice to know others can see in it what I see. Motzingg the bumper "chop" was actually very easy to do. It didn't take long and the after effect is really stunning, I couldn't believe how much of a difference it made. If your looking to do something that is an easy afternoon job, inexpensive and has a lot of bang factor that's the way to go. Sykanr0ng I have heard of that john Deere paint somewhere else an I think I might give it a try, seems like that would just suit this project to a T.
