Cross Member Removal
Ben68F250
Post by Ben68F250 »
Greetings all. I have a 1968 F-250 and I'm having trouble removing the automatic transmission. The cross member at the rear of the radius arms is preventing it from moving. I have the transmission and cross member unbolted but still no luck. Any ideas?
BobbyFord
Re: Cross Member Removal
Post by BobbyFord »
You must remove the intermediate crossmember. Mine needed persuading once all of the bolts were removed. Some were riveted in, so make sure there aren't any rivets holding yours in. I used a large leaded rubber mallet to hammer mine rearward away from the radius arm brackets.
alphawave7
Post by alphawave7 »
Mine was wedged tight too...required banging with a 10# sledge before it would even budge. Once it moved, it pretty much slipped right on out. Getting it back was was actually harder, so I don't envy the OP. :)
Ben68F250
Post by Ben68F250 »
Thanks for the information. I finally got it moved far enough to lower the transmission. Getting the crossmember bolted back in place was an exercise in patience though. haha
BobbyFord
Post by BobbyFord »
That crossmember is impossible to remove and install in a truck with a 460 and Super Comp headers. I had to cut my crossmember in half in order for it to be removable. I fabbed a bracket to reconnect the two halves. :eek:
flyboy2610
Post by flyboy2610 »
BobbyFord wrote:That crossmember is impossible to remove and install in a truck with a 460 and Super Comp headers. I had to cut my crossmember in half in order for it to be removable. I fabbed a bracket to reconnect the two halves. :eek:
Ya does what ya got's too! :thup:
Red Green
you'd better be right.
