55 F100 cowl vent install
- flyboy71
Re: 55 F100 cowl vent install
Yeah its over by about 1/2" or so but I may just sweep its curve into the cowl and section the hood to the same contour. The front curve will never match exactly but its pretty close. Im just happy I got it where its at. I used various templates to section and try things and this worked out pretty darn good.
-Jeff
- flyboy71
Well I finally got the vent assembly about 90% installed and closed the remaining vents. All I need to do now is trim the lower front edge and Im all set.
The hinge arms extend into the cab a bit and I might have to make an adjustment to the wiper motor assembly to clear them but it doesnt look too bad.
![Image](http://i649.photobucket.com/albums/uu220/jko0471/71%20F100%20Project/Cowlvent017.jpg)
![Image](http://i649.photobucket.com/albums/uu220/jko0471/71%20F100%20Project/Cowlvent016.jpg)
![Image](http://i649.photobucket.com/albums/uu220/jko0471/71%20F100%20Project/Cowlvent013.jpg)
![Image](http://i649.photobucket.com/albums/uu220/jko0471/71%20F100%20Project/Cowlvent020.jpg)
-Jeff
- Caseys71
Casey
![Image](http://www.fordification.com/images/forum/011-12.jpg)
- Mancar1
Looking real good. How hard we strive for the end result.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- fbomb100
I forgot about this topic . thats looking good there . Now you got me doing some thinking on that one ![Laughing lol](./images/smilies/icon_laughing01.gif)
- marvin2
Found this thread doing a google search for something else. Does anyone know how this turned out, looked like a really cool idea.
- flyboy71
I actually abandoned it. It turned out that the suck factor was pretty high.
-Jeff
- flyboy2610
As in looks, operation, or difficulty of installation?flyboy71 wrote:I actually abandoned it. It turned out that the suck factor was pretty high.
![Confused :?](./images/smilies/icon_confused.gif)
Red Green
you'd better be right.
Red Green
- flyboy71
All of the above. It didn't match the curve of the cowl. There are probably better ways to make a cowl door. My plan was to make it motor operated. I still have to vent assembly if anyone wants to give it a try.
-Jeff
Hello, do you still have the vent assembly??flyboy71 wrote:All of the above. It didn't match the curve of the cowl. There are probably better ways to make a cowl door. My plan was to make it motor operated. I still have to vent assembly if anyone wants to give it a try.
